![]() | Home > Maintenance & Modifications > Aluminium for Holes |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
I feel quite inadequate, I just used duct tape on the inside.....
Buy an old tub perhaps ?
I just bought some aluminium sheet from eBay and used some two part epoxy.
Scraped off crud from underneath, cleaned with WD40 then degreaser, put patch on, left for 24 hours. My patches all have a 4mm hole in the middle so I could clamp them tight whilst the epoxy was going off. Given that there is going to be very minimal metal-metal contact on account of the stuff you're using to stick them, I wouldn't worry too much about getting the grade exactly right. |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
Is it this panel?
[URL=] ![]() Click image to enlarge[/URL] I replaced it with a new one because of holes in the aluminium. Not difficult but time consuming. [URL=] ![]() Click image to enlarge[/URL] I glued a thin shim of rubber sheet between the steel crossmember and the new panel. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
How do you remove the white section of metal? 1999 Defender TD5 110
Lift the floor, drill out the rivets, use a grinder to cut it out leaving about 20mm lip.
Then use a scrapper to separate the sealed joints. Most awkward part is easing the folded corner uprights out to fit the new panel. |
