Home > Puma (Tdci) > 2.2 inlet manifold....where are you and how to access?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Im upgrading the lines from my Allisport intercooler on the 2.2 engine to silicone. The two long hoses coming off the intercooler to the engine are obvious swaps- however I have a third elbow that is apparently attaches to the inlet manifold. I cannot locate it or even see where it would go. it has a 2.2" OD on on one side and a 3"OD on the other
can you point me to the location and how to access and maybe the best way to swap?
thx
Marco
Post #574958 2nd Nov 2016 3:29pm
Manxie
Isle Of Man 2008 Defender 110 Puma 2.4 HT Keswick Green
Check if its between the airbox and turbo... Its only a guess.
Post #574985 2nd Nov 2016 6:00pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Down by the egr, as youre looking in the engine bay, right hand side, buried in between many pipes, the pipe you changed on the right that connects to a metal pipe, the other end of the metal pipe is where it goes.
I had to get the wife to get mine on properly as my hands didnt fit... good luck! Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #574988 2nd Nov 2016 6:13pm
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Keep following the metal outlet pipe from the intercooler ie passenger side(U.K. Rhd) It ducks turns ducks turns ducks turns then hides a bit. Think of the Big One at Blackpool. You will find the elbow at the opposite end from the intercooler tucked in quite tight against the block. . I found a silicon spray helped installation. ISTRC I actually dropped the water pump complete (sealed)from its mountings to help get at it. Looking at this pic I shall point you at the mounts I removed.
Post #575048 2nd Nov 2016 10:34pm
John Fair
I think I recall dropping off the auxiliary drive belt and undoing three? Bolts that mount the water pump to the block, keeping all water pipes connected. This allowed me to manoeuvre the metal pipe back onto the elbow. This was a short while ago so my memory is foggy. This was also on the drive and my hands don't work like they used to so you may not find removal helps you.
Post #575051 2nd Nov 2016 10:47pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I did change it myself because rift.
Not à easy job !
You do not see the part and you must have slim arms
Good luck
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #575083 3rd Nov 2016 6:07am
big110
thanks for all the help with this. got it done, BUT IT SUCKED! you need baby hands to get in there and do it! and cant access it from under because of that engine mount!
Post #575982 6th Nov 2016 11:59pm
YOLO110
Australia
NEVER seen so many pipes on one engine!! Confused Shocked YOLO... You Only Live Once...
Post #576011 7th Nov 2016 12:04pm
big110
NO KIDDING it's crazy mate. And things are fitted so backwards and tight it almost too much of a pain to want to work on her!
Post #576039 7th Nov 2016 2:46pm
