Home > Maintenance & Modifications > KBX thoughts, but not on looks?
CarMan
Each to their own and all that, but I once went to look at a used 90 with OEM headlight surrounds, but around the outside of those the paint was damaged in what I suspect was the outline shape of KBX (or similar) surrounds previously fitted and removed. In other words, had they rubbed away the wing paint? Has anyone any comments on this issue either positive or negative, but I am not looking for opinions on which looks best Whistle Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #574779 1st Nov 2016 6:50pm
OE can do the same, not really a lot you can do about it bar fit maybe clear protective paint tape. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #574784 1st Nov 2016 7:04pm
CarMan
Thanks Steve, interesting and obviously therefore not a problem until you remove and replace - Thumbs Up
Post #574786 1st Nov 2016 7:07pm
Thing is with the OE ones is it'll never be seen even if you swap. But KBX a bit larger will if it goes back to OE.
Personally, I'd use some 3M tape that's scratch or abrasion proof.
It was discussed here lately for another reason but it's clear and sticks right on. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #574788 1st Nov 2016 7:21pm
CarMan
Many thanks again, spot on Bow down
Post #574789 1st Nov 2016 7:22pm
Something like this: http://www.ebay.co.uk/itm/3m-Extra-Clear-H...xynRRSOVyh
I'd be looking for the brand 3M though, eBay isn't reliable for that as anyone can call it 3m adhesive etc or print some paper saying it.
But the 3m brand I said very good.
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #574792 1st Nov 2016 7:30pm
agentmulder
Kuwait
Vehicle came with KBX to me, which I removed and went original. Scantest of marks, not an issue from my perspective. Solved the bowel problem, working on the consonants...
Post #574799 1st Nov 2016 7:43pm
