![]() | Home > Td5 > Relay location and ID on a TD5 |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
driver seat box ( MY1999 rave )
working from foot well end first yellow relay cooling fan next one yellow relay compresses clutch A/C next one black relay Glow plugs next one black relay ABS return pump next one yellow relay ( main ) canter box fuse box ( MY1999 rave ) working from passenger side first yellow relay starter next yellow relay heated rear screen next yellow relay head lamp next brown relay sounder alarm next green relay fuel pump also ecu delay windscreen wiper unit brown / relay hazed warning black |
| fumiyasu Member Since: 19 Jun 2015 Location: Oxon Posts: 99
Thanks!
Will have to PDF this to my defender folder! |
land rover go to trouble showing you fuse in both place in rave my 1999 but not relay
your welcome Matthew |
Finally looked at it last night, it seems mine's slightly different for some reason, there wasn't a green relay in the central box. I did however have a yellow under the driver's seat which I tested to be the fuel pump relay so perhaps there were more than one configurations...
It seems a little loose but not too loose, I still cleaned the contacts and tightened the connectors a bit to see if it helps, so fingers crossed. I have a nanocom coming this week, so hopefully be able to get some fault codes and narrow down the search.. I also wanted to find the "main relay", would I be right to say that if I pull that out, the dash warning lights would not light up at all if I switch the ignition on due to the ECM not getting any power at all? |
do you have centre dash with radio and switches ? (MY 2000 rave)
Click image to enlarge Click image to enlarge as you can see ^ your fuse and relay layout is post face lift Last edited by dorsetsmith on 2nd Nov 2016 9:53am. Edited 1 time in total |
Hi Matthew,
Yes, I do have the centre dash thing. |
you will need to use wiring information post face lift MY2002
I see. Thanks again.
