Second Row Seat 110 Recliner Lever Gone Floppy
Has anyone had this problem, I have the lever has gone floppy and can't say erect, this may have be a problem with other members and I can guess it some sort of spring that has has broken any ideas? I need to sort this out as there is a chance that the seat would fold forwards with heavy braking or an accident. I have had a look at some diagrams but they are quite vague
Thanks, Michael
30th Oct 2016 8:54pm
rossy
Try this. I had the same problem and it worked for me :
Behind the seat there's a looped strap that you pull to tumble the seat. Sometimes it gets a bit jammed in the 'out' position. When you raise the seat back push on the strap i.e. as if you are pushing it into the floor. Everything should then lock properly
