Home > Td5 > Ignition switched supply under seats.
Loz2286
I'm thinking of running some switches from the cubby box to supply heated seats and some additional electrical items. Is there a convenient nt? I would use it to trigger relays while drawing the main juice from the battery directly.
Any thoughts guys? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #574150 29th Oct 2016 1:11pm
grafty99
On mine there is a single 15A fuse that runs from the ecu on brown wire. I think it's something to do with the egr as it stays live for about 30 seconds after the ignition iso turned off. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #574164 29th Oct 2016 2:34pm
dorsetsmith
ignition relay and wiring added to control heated seats power supply this wiring only in place from 2002 onwards
white 4.0mm wire Ignition switched supply only runs down to centre fuse box
the only other from fuse 4 centre fuse box green / orange wire for ABS control unit under driver seat box, wire may be in place it is switch by the Ignition !
Post #574192 29th Oct 2016 5:10pm
