![]() | Home > Maintenance & Modifications > Routing power cables from the battery box to the front bumpe |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Hi Russ,
Bit of an old picture: ![]() But you can just see the red cable going from the fuel cooler to the front. Back from the fuel cooler just pass the cables out through the holes next to the where the earth lead goes. There are loads of things to secure it to... just make sure it doesn't go over anything sharp, or an edge and you don't cable tie it to anything that might get damaged if put under stress. Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
As above, cable tied mine on top of the chassis and existed above the bumper, its a simple job mate and loads of places to cable tie up on
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
If fitting an Anderson connector to the front of the vehicle remember an isolator switch, a cover for the Anderson and a PVC sleeve. Helps keep connector cleaner.
You might find a read of this thread useful Brendan |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Cheers chaps
![]() ![]() 2011MY 110 XS USW Black |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Earth out the back of the battery box, + out the front
Along the top of the chassis rail to keep it out of the way Up into the top of the wing - done Mike |
