Home > Puma (Tdci) > Emergency - how to reseat the air box!
Bluest
Can anyone that has had there puma air box loose and back in again helpHow can I get the rubber grommet mount on the bottom to reseat in the bracket? No matter how much I push it won't go back. The bracket seems more likely to bend than let the rubber donut thing go back through?
Need to get this sorted so can get to work in the morning! 2007 110 TDCi Station Wagon XS
Post #571210 16th Oct 2016 1:00pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Put plenty of lube on the rubber to assist the box pushing back into it
You have to ensure that the rear ones (one on the side are lined up as you have to ensure these are engaged fully belfor the bottom ones will push in - Just push hard
Sorry cant be of more help - I struggled with mine
Post #571211 16th Oct 2016 1:09pm
Yep, lube it. Whistle _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #571216 16th Oct 2016 1:58pm
Jim_Bean
It is a real pain in the ass. I would grease/lube all 4 locations pins and make sure the rears are located first before trying to connect the 2 underneath the air box.
You do have to push pretty hard to locate them all.
Its a really crap design - especially if you have air con!
Post #571224 16th Oct 2016 2:31pm
Bluest
Cheers. Still struggling. The rear ones under the wing are fine it's the ones down below. Grrr 2007 110 TDCi Station Wagon XS
Post #571234 16th Oct 2016 3:19pm
