![]() | Home > Puma (Tdci) > Power loss |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
How many miles? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 64 ![]() ![]() |
Hello Steve, yes I forgot to mention the mileage. Its done 89,000miles
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1858 ![]() ![]() ![]() |
Would it seriously only do 5mph or was it just seriously down on power - 45mph flat out in 5th?
Keith |
Hello Ickle
Yes it was down to around 5mph. Definitely less than 10mph. I forgot to mention in my original post when I stopped and let it idle, it idled unevenly for a few seconds and then cut out. A friend suggested fuel problems and said this may not show on fault codes. The main dealer still has it so Im hoping they find something. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
Low pressure fuel system or VCV would be a strong contender.
Blocked tank vent?
As there's no fault codes I would think its an unmonitored part of the system, so a simple mechanical fault, so blocked breather, faulty VCV, turbo stuck etc. Best of luck Keith |
Thanks everyone. The main dealer has driven it for 45 miles without incident so will collect it today and hope all is well.
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
Would be interested in his diagnosis.
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Mee too.
I have the same issue randomly ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
FAO Hornet and Eduardo
Collected from the main dealer today they couldnt find anything wrong but I found something on the Intenet which points towards a volume control valve or fuel vapour valve as LR call it. Hope this helps. http://www.4x4community.co.za/forum/showth...trol-Valve |
Hummm,
My Defender is now with the Indy due the same issue. ![]() I hope that he found something if not I probably should change the VCV My problem is that I have the old BAS remap (with the black box) and If I change the VCV I must to run the re-learn process and I have 3 alternatives: a) Run over the remap file with the LR hardware and lost the possibility to come back to the normal file. Also probaly LR will detect the changes and will try to install the last normal file first. b) Change to the normal file and then run the learning process with LR but I will lost the Remaped file ![]() c) Change to the normal file, run the learning process, upgrade the Remap with BAS (250 GBP) So, the total cost of the optimal solution will be the 90 GBP + 250 GBP ![]() Any other thoughts to keep the remaped file? Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Nearly same as Option C that will give you.... 1 Full diagnostic control 2 Latest remap files as yours is 3 years old. Originally made 16/4/2013 3 Latest landRover software at the same time, your current calibration ID is FDD and the latest is FDE 4 To be able to never have to visit the dealers for diagnostics again as you will have your own engine tool. BAS2 RRC Hardware Addon . |
Thanks Pete!
For sure I will like to upgrade the remap (option C looks like the most logic one), but appears that I have the possibility to wait a little bit more to do the upgrade (for the sake of my pocket) Finally according to my Indy, my problem is the MAP sensor that have not reading the temperature correctly. BTW: Can be possible to have this kind of fault (variation of revs when iddling) due the MAP temperatrure failure? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
