Home > Puma (Tdci) > G/box output shaft
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
G/box output shaft
Hi All
I currently have my t/box out to replace a leaking front intermediate shaft 0-ring Big Cry
& decided to do all the bearings & seals while in there.
This is the state of the g/box output shaft...
Pic is without any cleaning, but there was quite a bit of sandy crud at the lower end of the casing.
Is it advisable to block the drain hole (well slit)?
Do think it looks 100's though?
especially after all the 'bad' posts about a non lubricated shaft.
Comments appreciated...
2012 2.2 90 000kms (60% off-road/sand tracks) Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #570685 13th Oct 2016 7:56pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
It is the bit under the boot that is a the concern if I remember so. there is another splined interface under there that is the famed weak point.
Post #570686 13th Oct 2016 7:58pm
Bushpig
Cheers Thumbs Up
Will check that in the morning then... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #570692 13th Oct 2016 8:11pm
Yes, it's the joint under the boot at the back of your picture that fails, not the transfer box primary gear splines near the camera.
Cut the cable tie holding the seal retainer (boot), pull the seal retainer and seal out, then pop the shaft out (use a slide hammer if necessary). Then you can see, inspect, and lubricate the infamous splines.
It's easier to do this if you remove the extension housing from the gearbox, by the way.
Post #570745 13th Oct 2016 10:37pm
