![]() | Home > Puma (Tdci) > Oil Pressure |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Red, I also have had issues with the Madman oil pressure sender: I replaced it 3 times in 3 years.
Finally, the last time, we took an extension hose and fitted the unit further away from the sump. Two years later and it's still going strong, so I can only assume that the high temperature close to the sump was causing issues. Also, check your earth points, as a bad earth connection will affect the readings. My 2.4, when at operating temperature, will show 4.5-4.9 at 100kmh, and around 5.2 at 120kmh (highway). my bets guess is that you need a new sender! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
Naks - that's exactly what I'm hoping. The behaviour seems too erratic for it to be anything physical.
Today I turned the ignition on after letting leaving the car off for a while, and it showed oil pressure at 6.7 bar! As soon as I cranked the engine, it dropped to 3.5 bar... Can't imagine any scenario where oil pressure remains that high with the engine off for a few hours! Did you replace your sensor with a Madman supplied one, or something else? redline PS - thanks for the comprehensive reply and sharing your experience! |
red, the pressure sender is a VDO one, I just got replacement units from Madman.
Sorry, I don't have the part numbers, but I'm sure if you email them they will supply the part number? Also, get an extension hose and place the new sender at least 10-15cm away from the sump. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
