![]() | Home > In Car Electronics > LED Reversing Light |
Simali Member Since: 25 Jun 2015 Location: Basingstoke Posts: 46 ![]() ![]() ![]() |
Anyone found a decently bright LED reversing light solution 2004 110 CSW (Called Yoda)
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
I will soon (hopefully next week)
Be changing my std rear lamps for Wipac LED's Assuming it goes to plan I may also look at adding another fog and reversing light to give this look.. (these are not wipac though) but would give more reversing light? The alternative would be to fit an extra light (lazer light) on the rear somewhere? ![]() |
I doubled mine up as above and chucked some of these modern sree bulbs in and I'm happy with the effect, I can see to back down our street to my parking space a lot easier now
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
There are a few ideas in this thread
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
NAS Spec lamp, ridiculous CREE LED bulb x2
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
^^^^ Okay, for reverse as non obligatory but not legal for other obligatory road lights. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 1st Oct 2016 11:04pm. Edited 1 time in total |
Pics might help
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Isn't that what the OP is asking for? Advice on upgrading the reverse lights ![]() FWIW, I also have bright LED CREE bulbs and NAS lamps for my fog and tail/brake lights. Never had an aisle with traffic plod nor MOT test ![]() |
Another option..
I fitted this which does help getting VERY close to things without.... Bump ![]() ![]() Click image to enlarge It also has built night vision 'lights' ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
I doubled up on the standard Wipac LED Reversing and fog lights. I guess it doubles up the light and is better also puts light both sides which is better. The reversing lights have 'blown' twice now and this set has to got back again, all the others are fine, just the reversing.
The other option is the Scenelight LED Strip which mounted in place of the rear washer jet or one each side at high level gives great light. DO a search on Scenelight. ![]() Click image to enlarge Since taking the photo I've actually had the fog and reversing light swapped around so the fog is on the inside to move further away from the indicators. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Wired as a worklight with switch on the dash, so you can use it when needed for reversing.
![]() Click image to enlarge Off position ![]() Click image to enlarge On position ![]() Click image to enlarge Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
I think member CY88 has a combined LED reverse/fog which he said was very bright on another thread. Standard NAS size so you can have symetrical 2 reverse and 2 fogs without needing any extra units. 2007 110 TDCi Station Wagon XS
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Mine had Doubled up old style lights so had to cover the holes when I went LED
