Home > Maintenance & Modifications > Tank Guard and 2" Receiver for TD5 90
Page 3 of 3 <123
alantd
They'll find it hard to type-approve a NATO hitch for a sankey surely.
There are only a coupe of solutions out there:
Bolt direct to the crossmember - easy to get approval on this - just get some longer bolts and bypass the receiver.
Use a receiver which keeps the NATO hitch quite high and therefore in-line (almost) with the trailer.
Dixon-Bate.
I'm guessing that there will be a way to have it assessed by then Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #53906 19th Jan 2011 4:44pm
Glynparry25
leeds wrote:
Well I live in the UK and seldom tow on the continent. Razz
Both our trailers are Ifor Williams ones. Both rated properly for the work they do.
Yes there are some dogs of trailers on the road which should be taken off the road. If a trailer MOT gets them off the road I will not complain!
Interestingly I saw a 2.6 tonne Ifor Wiliam box trailer being towed by a medium sized eurobox. `Trailer was all sign written so obviously a business trailer. There was me thinking cars in general (i.e. medium sized eurobox) had a general tow limit of 1200-1500 kg?
Trailer/driving laws are a nightmare at times to understand/comply with.
Brendan
Ifor Williams are awesome trailers and are WAY above all European standards.... I need to get one.
The problem with UK is that trailers aren't in any tests, and aren't regulated so no-one thinks about it. What is the rules with licences now? I know you have B and B1E (for trailers) but is it a different test like with C vehicles?
Dixon-Bate.
Dixon Bate 5 ton tow hitch (NATO hitch) is TUV approved and as long as it is bolted to the cross member it is 'type approved'
If/ when the law comes in, you will find all these companies that make reccievers will either stop, or get 'type approved' status... and pass the cost on... so it will cost you closer to £300 for something that used to cost £100. Then you will have to buy the type approved drop plate.... and so on- I am sure you get the picture- what a nause Rolling Eyes
Glyn Sheep
Post #53910 19th Jan 2011 4:54pm
leeds
All depends when you past your test! Post 97(?) need separate tests
My licence is B, BE, C1, C1E, D1 and D1E.
Stupid thing is I can drive a 7.5 tonne truck all day long and ignore driving hours etc. Put one small business item in and I need to use a tachograph and keep to driving hours etc! Restricted operators licence and another can of worms opens up! Don't get me started. Soap box away now. Rolling Eyes
Brendan
Post #53914 19th Jan 2011 5:12pm
Glynparry25
Brendan
Ahh, so there is a test now Thumbs Up I am full C+E (or is it C1E now?)driver so had to do a proper trailer test for that anyhow.
Glyn Sheep
Post #53917 19th Jan 2011 5:17pm
Page 3 of 3 <123
