Home > Puma (Tdci) > Safari Snorkel
Page 2 of 4 <1234>
--defender--
United Kingdom 2010 Defender 110 Puma 2.4 HT Zermatt Silver
Denis wrote:
Hi --defender--!
I didn't fit it myself yet. My friend did it - with total sealing. It takes him about 8 hours Very Happy And it was only disassembling and sealing, RAI was fitted before. Rolling with laughter
First seal all holes with some good sealant, then wait until it makes rigid. Then seal fittings among ducts. You need to seal everything. Without total sealing it is mere raised air intake not snorkel. No problems with water with proper sealing.
If you have a little experience in automotive works in my opinion it is better if you let to do such works as drilling to experienced one and yourself do sealing works. Or you may fit it as RAI somewere, and then make sealing yourself later.
hope that helps, all is only my opinion Very Happy
Thanks Denis, I'm not a novice - just that I've not needed to venture under/into my Defender much since I bought it. Weather permitting I'll give it my best this weekend. Cheers! If it ain't broke don't fix it!
Post #51282 6th Jan 2011 12:38am
Glynparry25
mse wrote:
My only comment - in my opinion - safari is the best snorkel in every respect...but the snorkel is an insurance not to play in bonnet depth static water!
Any snorkel is all in the fitting.... an incorrectly fitted Safari will be as useless as an incorrectly fitted Mantec, Southdown, Britpart etc. I like my Mantec snorkels, just got to remember to seal the inner bits which most places don't do.
The Royal Marine beach landing Rovers use the Mantec ones with extended tops (which also separates air from water (so it can drive in water over the windscreen)... one of the many reasons why Mantec is my fave Cool
http://www.youtube.com/watch?v=mKEG-uMsHio
Glyn Sheep
Post #51286 6th Jan 2011 12:48am
--defender--
Glyn Sheep
One reason for not buying a S/H Marine Land Rover! Extreme use indeed.. We'll I've already bought mine and I guess it'll help with the odd fording. Thumbs Up If it ain't broke don't fix it!
Post #51289 6th Jan 2011 1:06am
Glynparry25
Good reason not to buy any ex-military Land Rover.
Every snorkel/ RAI will help your engine on a daily basis... either stopping water getting in from fording to dust on the hot dry days. Worth while mod if you ask me Thumbs Up
Glyn Sheep
Post #51301 6th Jan 2011 9:29am
mse
Glyn Sheep
Mantec are no way as good as safari...i wouldnt trust those!!
My point was more around whatever snorkel you fit - they shouldnt be an excuse to go in 6ft of water Mike
Post #51440 6th Jan 2011 8:38pm
Glynparry25
I agree, and the reason why I have one (not at the moment as waiting for one on back order) is for piece of mind whenever I am off-road.... or even just a flooded road.
Why wouldn't you trust a Mantec? I have been usiing them for years, Camel trophy used them for years, Land Rover have them as approved parts, The British forces use them and I have never heard of one person who has had a problem with one.
Glyn Sheep
Post #51453 6th Jan 2011 9:08pm
mse
Glyn Sheep
Just a personal thing with the new ones (the older mushroom ones on a defender have a good rep).
The only experience i have had was around noticable airflow restrictions from a standard mantec (for the vehcile) on a 300 and td5 - this was the old design.
We actually monitored it and then went and swopped it on the same car for a safari.
That was the nail in the coffin for me with mantec. Mike
Post #51460 6th Jan 2011 9:18pm
Glynparry25
Personally the top for either should be binned and replaced with a spin top.
the Td5 and TDCi shouldn't be fitted with anything other than the mushroom type (Td5 one not 200-300Tdi) or the newer (LR) cheese block type.
Someone putting a 300Tdi snorkel on a Td5 is asking for trouble.... bit like putting a escort LE induction kit on a Escort Cosworth.... that is more of an error on the guy fitting it.
Glyn Sheep
Post #51462 6th Jan 2011 9:27pm
mse
Glyn Sheep
Sorry you misread a little
We had a genuine 300 and a genuine td5 mantec snorkels and ran them - observed engine performance reductions through test book and fitted genuine safaris on both and the issues went away and actually perfromance improved!! Mike
Post #51469 6th Jan 2011 10:14pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I've also heard people question airflow through the Mantec snorkel.
Post #51470 6th Jan 2011 10:17pm
Happyoldgit
You mean the new style plastic jobby as opposed to the old mushroom topped stovepipe ones that have the flexible rubber bit between the inlet and A pillar pipes? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #51516 7th Jan 2011 10:23am
MK
I tried both. Whatever wind speed you get , the Mantec does not work like the Safari. Because of the top shape the latter, conducts the air (together with bugs and Censored ). Anyway, none of them cope with the air mass sucked by the turbo. If you want a positive pressure then the RAI has to be of bigger diametre and facing the wind.
Anyway, if you look at the bottom section of both there is a hollow space which produces lots of restrictions (head loss). Puma 110" SW
Post #51521 7th Jan 2011 11:13am
mse
Both types of mantecs.
The safari's dont do this! Mike
Post #51624 7th Jan 2011 7:45pm
Glynparry25
I recently took a Mantec (LR one) off mine and haven't noticed any improvement in power... if anything it doesn't feel as responsive.
Also remember that if you run Safari you shouldn't use any aftermarket filters.... so anything you might gain in flow you loose in filter.
Glyn Sheep
Post #51632 7th Jan 2011 8:07pm
BIGFOG
Tell me more Glynparry - no aftermarket filters with a Safari Snorkel - why's that, I'm interested as I've recently swapped my ITG filter for a standard one and yes I do have a Safari snorkel...
Post #51638 7th Jan 2011 9:13pm
Page 2 of 4 <1234>
