Home > Maintenance & Modifications > Front Runner 110 Water tank
jst
Well i have had a front runner water tank sat in the garage for around 9 months now.
Its been a time issue plus i had been trying to find a way of attaching the 'tap' part so it didnt look too 'pikey' or could be ripped off the cross member - its meant to bolt to the underside of the rear crossmember.
So gave it all some thought and having came to the conclusion the easiest way was to have a disconnect system with the tap on a short piece of pipe, so stowed safely in the vehicle when not needed. Tried a few disconnects before settling on Koolance valves. they claim to only loose 0.2ml on disconnect or something similar!
The Big Outdoors overland activities/gathering event is fast approaching (13-16 Oct) so thought it was about time (last ten years with water jerry cans!) to fit the thing.
It was actually one of those jobs that went really well and didnt take too long at all!
Tanks fits neatly up in the rear passenger side arch.
Male end of Koolance i have fed in through the rear n/s jacking point, with it routed away from the exhaust. Sleeved the water pipe as well.
Actual end has a home made cover on it!
It has two jubilee clips to hold it in place inside the circular mounting working on friction fit!
The tail and tap
and all fitted.
Pipe is pulled out a fraction for connection to be made (push to make)
seems to work well so far, with no drips![/url]
It took 30L (or just over to fill) Just hoping it still got the same in it tomorrow morning.
Really please with a real neat solution utilising space that was otherwise 'spare' Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565140 19th Sep 2016 7:45pm
Retroanaconda
Interesting, never would have thought there was that much space there.
How does one fill it? Does the filler neck come up into the interior?
Post #565150 19th Sep 2016 8:07pm
Cupboard
That looks great Smile
I'm sticking with jerry cans for the time being so I can walk them to water to fill up. I may change my mind at some point!
Post #565151 19th Sep 2016 8:08pm
walfy
Looks a very neat solution. i was a firm believer in jerry cans but this loks like a great solution. Plus it makes it easier to get at the water.
As above though, How is it filled? Do you have to drill holes in the wheel boxes? That would be the only downside for me 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #565188 19th Sep 2016 8:42pm
jst
i was the same for years, then tried one in Namibia and thought you know what this works when verses the space of leaking jerry can and lifting in out all the time etc etc Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565227 19th Sep 2016 9:37pm
jst
yep you do - 1 x 52mm hole. would be easy to plate over if you changed your mind about it Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565228 19th Sep 2016 9:37pm
jst
filler neck inside, so also secure
as you can see i didnt use a hose to fill it, wanted to measure it in! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565229 19th Sep 2016 9:39pm
walfy
Another silly question. I can't remember about the wheel boxes on the 2.4. Are they flat like earlier Defenders or are they stepped like the 2.2?
Knowing my luck the whole would be on the sloped section 110 D250 SE HT
110 USW SOLD
Post #565236 19th Sep 2016 9:58pm
jst
mine are sloped, from memory all 2.4 and 2.2 with option of seating in back from factory have stepped/sloped seat bases.
hardtops, DCs have single flat surface, Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565246 19th Sep 2016 10:15pm
walfy
Thanks for the prompt response. Might add this to the list of future mods then 110 D250 SE HT
110 USW SOLD
Post #565247 19th Sep 2016 10:20pm
