Home > Technical > Rear diff fault??
Pinkfoot
2007 Defender 90 Puma 2.4 CSW Cairns Blue
Rear diff fault??
Is it normal that when turn one rear wheel the rear prop shaft turns but when turn propshaft by hand the same wheel does not turn?
Post #565045 19th Sep 2016 11:44am
MartinK
I believe so...
(and "Welcome" as this is your 1st post Smile )
When you turn the propshaft, the wheel under least resistance should turn...
Hence why people use diff lockers, Torsen Diffs, or Traction Control... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #565083 19th Sep 2016 3:16pm
jst
Re: Rear diff fault??
but the other wheel does turn i take it.
it jsut happens that the wheel you are turning has more resistance than the other wheel on the same axle. were you turning a passenger side one?
yes normal. diff is working Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565098 19th Sep 2016 4:45pm
Pinkfoot
Thanks for the reassurance guys
Post #565295 20th Sep 2016 9:14am
