Home > Maintenance & Modifications > Supplementary circuit
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
As I keep getting extra toys that need 12 v supply is there a circuit that you can tap into that will run a few things at once.[/i]
Post #50499 31st Dec 2010 4:11pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Re: Supplementary circuit
There is a few wires that can be used if you wanted but by far the best is to run new fused wires direct from the battery.
Pete.
Post #50502 31st Dec 2010 4:23pm
mick
I have thought about that putting a small fuse box in like someone on here but can I make it come on when I turn the engine on or would it have to be live all the time.
Post #50509 31st Dec 2010 4:55pm
Zinke
The small fuse box in the battery box is by far the best way. You can have it live all the time or you can run the power through a relay with a ignition feed.
I dont know what model you have but the ignition controlled wires in a TD5 are green and white, the closest one to the battery box is under the drivers seat. Just use one of these to the relay and then the new fuse box will only be live when your ignition is turned on.
Pete.
Post #50511 31st Dec 2010 5:12pm
mick
Thanks Thumbs Up
Post #50512 31st Dec 2010 5:13pm
mick
Post #50519 31st Dec 2010 6:13pm
mick wrote:
Might go for one of these http://www.fuzeblocks.com/index.php?pid=1#board
hey Mick,
the fuzeblock looks to be a good bit of kit, can you get them in the UK or will you order direct from the USA?
Post #50554 31st Dec 2010 9:33pm
mick
Post #50562 31st Dec 2010 10:32pm
leeds
Mick, have you consider one of these?
Twin banks of 6 fuses rated at 100 amps/bank or 30 amps/fuse
Main advantage is has common negative bus bars
HTH
Brendan
Post #50563 31st Dec 2010 10:41pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
HTH
Brendan
.............. meaning one cable to battery or something else ?
can you give us a site ?
thnks a lot www.newfoundland.gr
Post #50611 1st Jan 2011 5:10pm
mick
Post #50613 1st Jan 2011 5:23pm
leeds
It really depends on what you intend to run through this auxiliary fuse box.
Each bank of 6 fuses is capable of 100 amps, so using both banks to maximum capacity that would require a 200 amp cable and for a single cable that would require a cable of 25 or 35mm2 which is a big cable.
If only using say two third capacity say 60-70 amps per bank you could get away with two 10mm2 cable.
If only using it for very light use then you could say use two 2mm2 cable as long as each bank is limited to about 20 amps
So no one single simple answer really on number and size of cables.
It is better to have a cable size above what you actually need rather then a size down.
The person fitting it will need to work out actual size of cable dependent on actual use and err on the side of safety.
It is a good idea to split any large current using circuits between the two banks of fuses rather then one bank having all the large fuses and the other bank all the light fuses.
Hope that makes sense
Prices in the UK varies between £31 and about £50
Brendan
Post #50614 1st Jan 2011 5:33pm
pouf
yes Brendan, it makes sense !
great help.
happy new year www.newfoundland.gr
Post #50624 1st Jan 2011 6:24pm
discocuzzy
Thats what im using Brendan, good piece of kit Thumbs Up You cannot teach stupid people to do clever things
Post #50639 1st Jan 2011 9:39pm
