Home > Puma (Tdci) > VCV replaxemetn
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
VCV replaxemetn
I am looking into a fault with my 2008 2.4 110 and it looks as if the VCV might well be at fault.
I know you need to do a pump learn after its changed but will the vehicle drive after its changed without calibration or does it have to be done at the time. What I am thinking is changing the VCV at home and driving it to the dealers (about 3 miles away) to have the pump learn done.
Anyone know?
Dave
Post #563030 10th Sep 2016 10:50pm
dgardel
Italy
yes you can drive it.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #563096 11th Sep 2016 9:55am
Cold_n_Wet
Norway
You have to get the engine to a certain temperature to be able to do the pilot learn anyway so driving to the dealers should not be a problem. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #563136 11th Sep 2016 2:49pm
