Home > Puma (Tdci) > 2.4 Puma Engine Surging
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Having an issue recently when I change gear the engine revs surge (not to be confused with holding revs). This seems to happen intermittently but generally around 2700 revs.
Any ideas what could be causing this?
Mark
Post #562632 9th Sep 2016 7:43am
hornet
First thing you should do is check fuse of brake-light. If thats fine, read
http://www.defender2.net/forum/topic579.html
Feedback appreciated
Post #562637 9th Sep 2016 8:12am
vaucluse
Hello Hornet,
Thanks for your reply. I have read your linked thread but can say it's not the same issue. This is a very recently occurring issue and is intermittent (50-60% of the time). Clutch switch replaced yesterday and it's still happening.
Mark
Post #562654 9th Sep 2016 9:37am
Any DTCs?
This could be a VCV fault. VCV faults can cause many strange symptoms, usually without DTCs.
Post #562670 9th Sep 2016 11:21am
vaucluse
Hi Blackwolf,
Vcv was replaced also and it's still surging - no faults registered.
Interestingly it's only occurring in the 2500 to 2800 rev range.
M
Post #562681 9th Sep 2016 11:50am
Is your EGR valve working?
Post #562687 9th Sep 2016 12:42pm
vaucluse
yes no issues with EGR
Post #562700 9th Sep 2016 1:38pm
Eau02467
It sounds like clutch switch but given you have replaced it i would look at other things in same area. Is the wiring to switch intact? Also When was the clutch fluid last replaced? Old fluid may not be holding up to hydraulic pressure and not activating the switch.
Post #562802 9th Sep 2016 8:48pm
Eau02467
Also another cause can be sticking turbo actuator
Post #562803 9th Sep 2016 8:49pm
vaucluse
Clutch fluid was changed last month.
Will need to check the turbo actuator - was thinking along those lines and also need to check the turbo modulator harness whilst I'm at it.
Thanks
M
Post #562829 9th Sep 2016 10:03pm
