Home > Maintenance & Modifications > Extended front seat travel in a 110 utility
Curtis-Bay
I have tried installing seat runner risers in an attempt to gain a little more leg room in the front of my 110 but I now feel "perched" on the seat due to the increased height. Is there an alternative way to mount the seat further back without the need to raise it above the lip on the rear of the seat box?
Is it OK to notch the raised lip on the seat box (adjacent to the rear of the runners) to allow the seat runners to be mounted further back?
Any advice / photos greatly appreciated.
Post #561697 5th Sep 2016 8:29pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I know what you mean about the 'perched' feeling as I had it too for a start (I made 1 1/4" nylon spacers to raise mine up), but give it a week or two and you probably won't notice it any longer.
I'd stick with them and see how you get on.
Post #561713 5th Sep 2016 8:56pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Not sure if your 110 still has the bulkhead behind the seats but I have just fitted a bulkhead removal bar "U" shape and this allows greater movement. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #561796 6th Sep 2016 8:52am
Curtis-Bay
The Utility is a 5 seater so no bulkhead, just that irritating 1" lip across behind the seat rails.
I think I saw a thread about cutting this lip to allow the seat rails to pass through it. Has anyone got any information.
Post #561864 6th Sep 2016 3:13pm
Curtis-Bay
So tonight I had a fiddle with the seats in my 110 today here is what I found.
I removed the seat risers and made a pair of 25 mm high spacers for the rear of the runners out of box section. I installed the seats with the standard spacers fitted at the front (these are about 5 mm thick) and the home made spacers at the rear. I did not install the factory spacers at the back since I found that they were not needed.
I refitted the seats back in their normal location but with the rear of the seat lifted by around 20mm (thickness of home made spacers minus factory spacers)
The moving part of the runners attached to the seat base can now pass over the rail at the back of the seat box and offer around 40mm more travel than before. This was so easy it beggers belief. Now I have a virtually standard seat position with more travel. No cutting required and even the standard seat bolts are long enough.
I hope this is of some use to others.
Post #561971 6th Sep 2016 8:33pm
leeds
Have a look here
Brendan
Post #562012 6th Sep 2016 10:11pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I use those on mine, very good and don't lift the front by more than about 5mm
Post #562017 6th Sep 2016 10:51pm
AJC
I used the ones from 4x4 over lander, however like yourself, i felt perched at the rear and the front was too low, so i then spaced the front up another 15mm and i'm now happy, i did kind of forget about the change of seat position then. And now it's just right for me.
Post #562039 7th Sep 2016 6:56am
Good call Curtis-bay, it's easy to just buy an off the shelf "fix" but like your post, with some thought you don't need to spend over £40 to make your seats move backwards enough. I started off by just fitting washers to the rear (did consider cutting the rib/fold )
Peoples thoughts, ideas and fixes make this forum great
Post #562059 7th Sep 2016 8:12am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I got mine from Brendan too - they really help my knees which would get really painful on long runs. You soon get used to the slightly different seating position. Euro-Leafing to infinity and beyond.....
Post #562221 7th Sep 2016 7:50pm
VeeTee
Netherlands
Re: Extended front seat travel in a 110 utility
I wonder if someone tried this, I am really curious to know...
Some time ago I installed MUDSTUFF Seat Rail Extenders, but I find they rise the seat too much. I am 6' 1" and with these rail extenders I feel my view out of the windows (especially side window) is restricted and I have to bend over to for a clear view out of the side window...
I have a Station Wagon, so no bulkhead, and wonder if one can cut the lip down at the two places were the seat rails are. Would this have negative effects, e.g. compromising strength etc. ?
I looked at the rails from 4x4 Overlander, but these also raise the rear of the seat by 30 mm, and thus impair visibility ...
Opinions please! Cheers, Vincent
MySite
Post #590939 7th Jan 2017 12:54pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
I bought the Mud Rails but also found them too high
I reduced their height to about 5mm at the front and 15 at the back(to allow for the seat bolts)
I also cut the lip down to allow the rails to sit lower
This worked well for me and the landy has not split in half yet due to weakening this joint
Front of rails
Rear protruding through the lip of the bodywork
Post #590982 7th Jan 2017 3:12pm
VeeTee
Netherlands
Thanks! Thumbs Up
I'll have a go then when the snow and glazed frost here have gone. Cheers, Vincent
MySite
Post #590994 7th Jan 2017 4:31pm
jst
i found by raising the rear to clear the lip (usually the rear is raised more than the front) that the angle of the base changed to the extent that i found it uncomfortable with std LR seats on long trips. something i had never felt before (believe it or not...) Osnabruck to Devon was a regular at one point too!
anyone else ? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #591128 7th Jan 2017 10:42pm
Cupboard
I haven't found the new angle a problem.
I went the much lower-tech route of just fitting spacers under the rear fixings on the seat slides. You don't actually need to move the slides back because there's plenty of travel left in them when they hit the lip on the box.
Post #591308 8th Jan 2017 5:41pm
