Home > Off Topic > hp printer - IT support
Caterham
I have a bad feeling I know the answer to this. bought a printer for the father in law to help him out - a HP 2035.
unfortunately I don't think it's suitable Big Cry
the idea was the printer would be connected to his router so he can print from anywhere in the house via his wireless connections / router, only I don't think you can with this printer as it's only got a parallel port and usb connections.
Help. Can it be done?
many thanks,
Post #560590 1st Sep 2016 8:31pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Connect it to a PC and then share the printer. You should be able to connect to it wirelessly over the network.
Only problem is that the PC will need to be on while your printing.
HP do a lot of wireless printers - for not a lot of money....
or you can add this wireless module... http://store.hp.com/us/en/pdp/hp-nfc-wireless-1200w-e5k46a-aba
cheers
simon
Post #560595 1st Sep 2016 8:36pm
Caterham
many thanks,
no other computer in the house and printer already purchased / arrived today Big Cry
doing some research it looks like there might be a chance of connecting it to the router (if the router had a usb port - but it doesn't) - perhaps a different router would be a good option?
o. that wireless device looks good. Thumbs Up
Post #560598 1st Sep 2016 8:38pm
Stacey007
Hello
Normally you would need a Network printer to do this so the HP would be a HP2035n
However this bit of kit may help Smile
http://www.lindy.co.uk/usb-firewire-c4/usb...AjjW8P8HAQ
I used this to share a hard drive and access it from different PC's. looking at it though it will work how you want. I may even have one of these if I search.. look into it and see what you think.
Other bits of kit will be cheaper this is a good make we use in AV installs in work Smile
Post #560600 1st Sep 2016 8:41pm
couplands
I would return the printer and get a wireless one. Did you want/need a laserjet printer (black & white) rather than a colour inkjet..?
The inkjets would be cheaper to buy.
cheers
simon
Post #560601 1st Sep 2016 8:42pm
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
Hi
It's not wifi enabled so it can't be used as a stand alone, however if you plug it into your home router it will work as a network printer. So not all bad, just read the speck.
Good luck setting it up
Thumbs Up Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #560602 1st Sep 2016 8:43pm
couplands
^^^ I think its only the "n" version that is network enabled, could be wrong...?
Caterham, what version did you get..?
cheers
simon
Post #560604 1st Sep 2016 8:47pm
Caterham
thanks guys - really appreciate the comments / offers however Panda's comments seem the most encouraging.
I'd like to connect it to the router - I'm not interested in it being stand alone. In an ideal world I'd like to wire it into the wireless router and print wirelessly from laptop via router but not exactly sure I can especially as the router doesn't appear to have a usb socket just 4 rj45 sockets?
Post #560605 1st Sep 2016 8:47pm
couplands
If you want a simple printer, this is about as cheap as you can get...
http://store.hp.com/UKStore/Merch/Product....mp;sel=PRN
cheers
simon
Post #560606 1st Sep 2016 8:48pm
Stacey007
If its a HP you need the 'n' or Network version.
I doubt yours has a RG45 socket on the back? if it does yes plug that into your router.
However the box of tricks I mention above turns it into a network printer.
inkjets are cheap as they drink ink, Laserjet if all you need is B & W will be much cheaper to run.
Post #560614 1st Sep 2016 8:57pm
Caterham
I'd like to stick with the current printer if possible.
yep it's NOT the 'N' version.
Stacey I'll have a look into the kit / option you've indicated as I'm not sure what it is at the moment but looks like the way forward. thank you.
Post #560615 1st Sep 2016 8:58pm
Stacey007
^ Your printer with the box of tricks will work.
Plug the Printer USB to the box of tricks.
Plug an RG45 lead from box of tricks to the router.
Locate the printer from any device connected to your internet to print.
Job done Smile
Post #560618 1st Sep 2016 9:01pm
couplands
^^^ agree, that box will be the only way forward.
cheers
simon
Post #560620 1st Sep 2016 9:03pm
Caterham
Hi Stacey,
I think you're right and believe it the best way forward all things considered.
More than happy to buy yours if it's going spare or I'll order one up. Many thanks. Thumbs Up
Post #560622 1st Sep 2016 9:06pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
You need to search for a wireless print server Thumbs Up Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #560625 1st Sep 2016 9:10pm
