![]() | Home > Puma (Tdci) > oily intake manifold and burning oil |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
it could be the halfords oil, oils do actually evaporate when hot, we have an issue at work with over 200 engines where we were seeing excessive oil and carbon in the turbos, lengthy investigations with lots of testing have pretty much proven we had an oil (bad batch) that exceeded the evaporation limit for the engine
(The NOACK Volatility Test, otherwise known as ASTM D-5800, determines the evaporation loss of lubricants in high-temperature service.[1] The more motor oils vaporize, the thicker and heavier they become, contributing to poor circulation, reduced fuel economy and increased oil consumption, wear and emissions.) our crank case separators could not cope and the oil was getting to the turbos etc, as the PUMA has no separator at all evaporation goes through the turbo the intercooler , egr and everything else gumming it up. Another good reason for using quality lubricants DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Thanks for the advice re quality oils.
If Oilman reads this - can we confirm all oils sold via Opie are quality oils. Just asking as this is an area where i know very little and have to trust makers product descriptions |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
Thank you LR9
I hope you are correct in my case and that after a mere 3500m with that oil no damage has been done. Of course if the same symptoms persist with the Castrol then thats another story ! . |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Does the oil have to be topped up ?
The engine oil level should be checked regularly to prevent incidents. A small amount of the oil that circulates in the engine is always burnt (an engine in good condition consumes between 0.2 and 0.5 liters of oil every 1,000 kilometers), but successive top-ups are no substitute for an oil change. Accordingly, it is natural that an engine consumes a small amount of oil, which can be offset by top-ups between oil changes; however, excessive need for top-ups can be an indication of mechanical problems (leaks, etc). Taken from this.... http://www.total.co.uk/lubricants/faq-lubricants.html It is impossible to get all of the oil out of the sump when you drain it owing to the depression in the sump just behind the bung. Also a small amount will be trapped in the filter. Add that to the caravan towing and I'd say you have nothing to worry about. Short journeys with stop/starting will also lead to a small consumption of oil. I'd say if it was Halfords own brand you used you have nothing to worry about as it's made by Comma. I have used Comma XTECH 5W-30 brand myself and have no complaints. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Really? ![]() Then there must be something wrong with the condition of mine, as it does not consume anything at all. ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
That was taken from the Total Lubricants site.
I have two Pumas. One would do a fair amount of short journeys as well as long journeys and would use some oil. The other Puma only does long journeys and does not need topping up. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Do you have a raised air intake or snorkel? Ive been made aware that this can increase the oil in the intake pipe due to the turbo sucking air from the passage of least resistance... IE, if it cant get the air quick enough from the air intake it will suck air from the breather pipe too resulting in more oily air being used, more oil in the pipe work.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
A worn turbo will cause oil to be present in the induction system, potentially in large quantities.
An engine I bought for spares some time ago, which had been removed because it produced excessive blue smoke and was believed to be a victim of the piston cooling jet problem, had about an egg-cup-full of oil sitting in the turbo compressor but the induction side was cleam as a whistle. The turbo shaft had about 1/4" of longtitudinal movement, and although I haven't stripped the head or bottom end yet, I now believe that the basic fault was a worn turbo rather than anything more catastrophic. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
And with mine also: 6 years/69,000 km and not a single drop of oil consumed ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Thanks for the replies
I have no snorkel and as far as I'm aware the turbo is OK, no loss of power or weird siren/dentist drill noises. MPG is the same as before. Until the last oil change the level always stayed right at the top of the dipstick and I don't remember drained sump oil ever smelling quite so 'burnt' before. |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
And with my 300Tdi also: 20 years/370.000 km, no top ups required between oil changes. ![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
