Home > Maintenance & Modifications > Accessory drive belt lifetime. 2.4 Puma
As title, what is the mileage for changing one? Is it 70k if I remember?
Mine tends to squeak a little on a warm start very occasionally, I'm 99% sure it's the culprit and doesn't do it often.
Seconds after starting and running it doesn't do it at all.
I think it's the inertia from starting and when the belt is warm.
Cold starts it never does it so it's obviously a little bit of slip, I'm not worried abiut it but keeping an eye on it.
Post #559336 27th Aug 2016 3:44pm
driver9
10 years or 120k miles according to LR service checklist.
Post #559344 27th Aug 2016 4:57pm
Ah I see, well I'm on 53k but my 90 is 9 yrs this Autumn.
So coming up.
Don't suppose you know the price off the top of your head a new genuine one?
Quite easily change it myself so that's no problem.
Post #559345 27th Aug 2016 5:06pm
driver9
Think the belts are part no PQS500600 for belt with air con compressor or PQS500610 without air con. Both are £40 ish for genuine. Try Dan at Duckworths for a price.
As an alternative to genuine I`m not sure if Gates make the belts. I understand they are one of the better
manufacturers of cam belts.
Post #559362 27th Aug 2016 6:42pm
Not too bad then, I was expecting about £120. Shocked Laughing
Dan is always good with these sort of things.
Thank-you driver9, appreciate your time taken to comment. Thumbs Up
Post #559365 27th Aug 2016 6:52pm
Leviathan
I got a genuine one from ebay 2 weeks ago for £9 + postage, so have a look on there.
Changed it in 20 minutes easy, following advice on here to remove the tensioner.
The original one was dated 2007 so could be 108k miles old and still looked fine.
Post #559513 28th Aug 2016 12:27pm
Will do, thanks for the tip. I had mine off too just a couple of months ago it too looked in good condition.
I kept it as clean as possible along with the pulleys but seems to slip a bit. (Only rarely).
Post #559518 28th Aug 2016 1:26pm
Eduardo
I changed mine after 200,000 km (as per manual), without apparent damage.
Cheers Eduardo
Post #559526 28th Aug 2016 2:58pm
Cupboard
They're really not that expensive from AF:
www.advancedfactors.co.uk/7pk2958-dayco-au...3619-p.asp
£23
Post #559555 28th Aug 2016 5:29pm
