Home > Maintenance & Modifications > Defender 110 doors and windows - insights needed
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
I am looking to work on the landy and trying to get most' things ready, so at least the job has the parts I expect. in this vein i have a few questions:
    looks like the plastic window spacers etc.. has perished - so I need t replace (does this impact electric windows closing?)
    see the pics taken in the door - this is lower 'guide' for the 4mm window glass (this is what is referred to as channel?), these look out of shape, can these be replaced (part #, Name ?) and the rubber/felt as well (Part # name?)
    lastly any aftermarket that works or lasts linger than original ?
any other guides/gotchas or tribal knowledge you can share will ensure my weekends are not ALL consumed...
Post #556607 17th Aug 2016 8:18am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
The felt/rubber channels are available as parts and easily changeable. It will require the window mechanisms and glass removing. It is a simple but fiddly task. The first door will take a lot longer than the second as you learn!
The channels are held in by self tapping screws through the channel. They will be corroded and need replacing. They may need drilling out. They need to be countersunk screws so as not to catch on the glass. There will be some spacer bits between the channel and the door. These may be corroded.
Suggest you also make sure you have spare plastic bits that connect the glass to the winder mechanism as these often break or come off. These need a strong glue to refit.
This page from the parts manual might help.
Post #556666 17th Aug 2016 1:31pm
itolond
Great thanks for the insights, few questions just so I am clear:
Still getting me head around ordering parts /names. Theses are referred to as "runners" can can be replaced (self tapping screws) and the felt rubber will also be replaced. (I don't see runners on the parts list or the felt rubber)
is there a part ref for the felt/rubber?
Bits refer to Glazing rubber?
Assuming 'runners; cannot be replaced - I am guessing these can be straightened (best practice?)
Post #556848 18th Aug 2016 12:53am
itolond
OK - got it
i thought the runners were broken in 2 parts but i now see they travel up the entire window,on ordr i guess these come with felt rubber inserts?
the channels - simply act as spacers to position the runners - correct?
Post #556851 18th Aug 2016 3:04am
Scotm
I will try and clarify a bit more
Items 4,5,6 are the rubber/felt channels that the glass runs in. They look like this:
Unfortunately the diagram only shows up to 1994. After 1994 they changed item 2 to the two plastic brackets I am referring to (Part number STC4787). They look like this:
Post #556873 18th Aug 2016 8:21am
itolond
great thanks..... think i have my head around this now.
the parts (post 1994 model - where to these fit on the windows?
Post #556994 18th Aug 2016 4:32pm
Scotm
The plastic bits glue to the glass and fasten to the key holes on the winder mechanism - see this photo.
If you wind you window down while you have the door trim off it you will see.
Post #557184 19th Aug 2016 11:32am
itolond
Brilliant, thanks for your help
Post #557352 20th Aug 2016 12:23am
