Home > Puma (Tdci) > Interior heater not going back to cool...
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi,
Just after our first stop in a 1300 km trip, after fiddling with the temp knob (full hot), it wouldn't go back to cool.
We drove the rest of the trip with the windows fully open as the aircon wasn't working ieder.
It is now around 30 degrees in Spain. And the heater is only blowing hot air. It is hardly to drive as I am burning my knees.
Any suggestions what could have happened (is broken)?
Suggestions much apriciated as we have to travel the 1300 km back next week (with 4 girls mowing about the temp 😁)
Post #556575 17th Aug 2016 12:14am
ericvv
Goeie morgen, niks verkeerd met 30 graden natuurlijk. Binnen een paar maanden (of eerder) vragen we daar weer naar. Cool
Now, I think that possibly your solution might be the same as the one in the posts toward the end of below thread. It could be that same heater valve, and maybe as easy to correct as Gren did. Take a look.
Eric
http://www.defender2.net/forum/topic47480....ontrol+hot You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #556590 17th Aug 2016 5:34am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
The heater is controlled by a simple water valve in the engine compartment.
In order to find out if it is the valve or the cable thatīs at fault, you will need to disconnect the two. Under the bonnet, left hand side (on a LHD model), high up near the bulkhead. Once disconnected, you should be able to move the valve itself to itīs fully closed position, and put an end to your plight!
By the way, the AC is probably working, but the heater is too powerful to overcome it. So once you cut off the heat, the cool air of the AC will return.
Good luck! 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #556592 17th Aug 2016 6:08am
HardCharger
There is a little flap thing on the heater in the engine bay, this is sometimes not closed properly via the temperature knob. Just give it a push down to close it all the way and you should find the AC working properly again. In this situation, the AC still works, it's just being overpowered by the heater.
I hope this helps.
Post #556602 17th Aug 2016 7:36am
TopQ1967
Thank you all.
Course was indeed at the engine bay heater valve side. The clip holding the cable was lose. Heating, full-open was easy by pushing the complete cable, but closing not as there was no resistance by the clip.
I am able to drive home safe (cool) now without to much hassle 😊
Post #556634 17th Aug 2016 11:14am
VeeTee
Netherlands
Wild Card 90 wrote:
... Under the bonnet, left hand side (on a LHD model), high up near the bulkhead...
As far as I know - at least in my Defender - the heater matrix and valve in a LHD model sits at the right hand side (that is standing behind the vehicle and looking forward. Wink
(On the left side there is de brake servo). Cheers, Vincent
MySite
Post #556756 17th Aug 2016 8:10pm
Wild Card 90
Thanks VT. It depends how you look at it, doesnīt it? Laughing Laughing Laughing Laughing 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #556764 17th Aug 2016 8:38pm
VeeTee
Netherlands
Indeed. I am not an Englishman, but as the English say, there is only one right side and that is the left side... Rolling with laughter Thumbs Up Cheers, Vincent
MySite
Post #556767 17th Aug 2016 8:42pm
Wild Card 90
Dear VT, lets sort this out properly, shall we?
if you are right (er, I mean correct) and the heater valve - quote "in a LHD model sits at the right hand side (that is standing behind the vehicle and looking forward."
- Iīll buy you a crate of beer of your choice.
If, however, it is on the left hand side (also viewing from behind) above the brake servo, and not as you describe, on the same (right hand) side as the heater matrix, then Iīd like 12 bottles of your best local brew.
Are you up for it? Very Happy Very Happy Very Happy Whistle Whistle Whistle 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #557015 18th Aug 2016 5:46pm
VeeTee
Netherlands
As I said before - and I also explicitely mentioned my LHD model - under my bonnet the brake servo sits on the left (what is very logical, because it also happens I sit on the left, otherwise you have to be very gymnastic to touch the brakes), and the heater on the right.
I just took a picture, standing before the bonnet looking aft, so you have to correct for that standing at the rear looking forward (and in the latter position it is not possible to take a picture with open bonnet Laughing ).
So... cheers! Thumbs Up
 Cheers, Vincent
MySite
Post #557018 18th Aug 2016 6:09pm
Wild Card 90
Dammit VT you got me there! Thumbs Up Thumbs Up Thumbs Up You did say "at least on my Defender" and you were right, as its a TDi. Embarassed Embarassed Embarassed
Well done.......well almost. As we are in the TDCi section, and the OP was asking for information applicable to his 2012 2.2....ok, ok Iīm buying! Embarassed Whistle
Just for the record, hereīs one they did recently.... Laughing
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #557023 18th Aug 2016 6:25pm
VeeTee
Netherlands
Haha, there you have a point too! I only looked at the op's country flag, and thus supposed he was driving a LHD model. However I did not realise or know that there is such a difference between 300 Tdi and the later models - concerning heater location and layout of course. Thought because of the location of the brake servo the heater on the later models, even LHD, couln't be on the left.
So I guess we're sort of quitte - must have a beer together sometime and talk Land Rover ... Thumbs Up Very Happy Cheers, Vincent
MySite
Post #557025 18th Aug 2016 6:34pm
Wild Card 90
Thumbs Up Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #557135 19th Aug 2016 5:59am
