Home > Td5 > exhaust bolts
yanto
Wales
exhaust bolts
Hi guys
I'm swapping my mid box for a straight pipe and the bolts are rusted. Anyone know what bolts I need and do I need exhaust paste?
Thanks
Post #554986 10th Aug 2016 12:39pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Hi, I did the same swap with mine recently.
I can't remember the size of the bolts but as they bolt straight through once the old bolts are cut out its not that critical.
If you are reusing the rear section and cutting the old bolts out you will need to be careful with the angle grinder.
I thought my rear section was ok but the flange was heavily corroded and it was just starting to crack behind the weld.
I always use a light application of exhaust paste just to ensure a good seal.
The front seals on a ring which is part of the cat pipe and doesn't use a gasket.
The rear has a metal gasket which is widely available.
The only advice I would pass on is to loose fit it first and check the clearances are all ok.
You can adjust how the pipes sit by the angle you bolt the front joint up at.
On mine the cat was pulled too close to the chassis rail until it was adjusted.
Hope this helps. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #555021 10th Aug 2016 1:37pm
dorsetsmith
Post #555136 10th Aug 2016 8:58pm
yanto
Wales
Thanks guys
Post #555159 10th Aug 2016 10:20pm
