![]() | Home > Maintenance & Modifications > Dcpu rear tub bulk head part number |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
ABB710040 - Bulkhead
AQU710010 - Lower Support AQU710020 - Upper Supports 02' 110 TD5 Double Cab Rebuild Thread |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 ![]() ![]() ![]() |
Top man 👍🏼
Does anyone have any close up images or a double cab tub, and how the support brackets fit around the bulkhead? Cheers
Badly, using adhesive, pop rivets and random spot welds. You would be better just using some aluminium angle section and riveting it in. On mine, thebangle sections are on the cab side. I have seen another where they are on the tubs side so i guess JLR made it up as they went 02' 110 TD5 Double Cab Rebuild Thread
Would you be able to get a pic please?
