Home > Maintenance & Modifications > Hard Top Sides
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Hard Top Sides
Wondering if anyone could shed any light on an issue i've got currently. Just fitted up my roof and sides ready for the respray next week, converting a pick up to hard top.
I got the two sides from different places. One side lines up flush with the capping on the tub. But the driver side sits about a inch in on the capping. On both the side and rear. Very noticeable when comparing the two sides.
I thought that all model years would fit, the side came from a tdi and I am fitting it to a 2006 td5 pick up. Does anyone know if there was a slight difference between the two models ?
Post #553649 4th Aug 2016 11:55am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Assuming your truck is a 90 (from your profile) is it possible the panel which does not fit has come from a 110?
I believe that 90 and 110 hard top sides are different.
Post #553670 4th Aug 2016 12:34pm
Tiger
110 (88") are shorter so that wouldn't add up
Post #553671 4th Aug 2016 12:39pm
L90DNY
It is definitely from a 90, I removed it myself at a local breakers. It fits fine, but it is in about an inch from the edge of the cappings on both the side and the back, where as the other side is flush.
Post #553683 4th Aug 2016 1:28pm
Mo Murphy
There are 2 types of hard top side for the 90. The earlier ones have an external vertical rib on the front edge and a horizontal anti drum bar across the skin on the inside.
The later sides don't have the front rib and the anti drum bar is vertical.
Dimensionally they are the same with the exception of the protrusion of the front vertical rib.
When fitting replacement sides, I've always found it easiest to loosely bolt the sides to the tub and the roof and make sure that it all moves within the range I need, investigating and addressing any lack of adjustment before starting to tighten bolts. A common one is the internal bracket at the bottom of the side about half way along. These need slackening off to allow the panel in or outboard and tightened once bottom of the side is located correctly and the corner bolts are tight. Once the bottom is right you can centre the roof up and tighten those bolts.
HTH
50 Shades of Pennine Grey
Post #553691 4th Aug 2016 1:52pm
L90DNY
Ok thanks for the info, this has a vertical bar on the inside, which must mean it should fit flush, if properly adjusted ?
Post #553692 4th Aug 2016 1:58pm
Mo Murphy
Remember, it's a Land Rover 😉 The Land Rover 90 - Many are called, few are chosen.
Post #553701 4th Aug 2016 3:23pm
mk1collector
As far as I'm aware the panels were put in place at the factory and then the holes drilled by a human to bolt the sides up (no robots that get the holes in the same place every time) so the holes could have been drilled in different places. Ray
My build thread
Post #553704 4th Aug 2016 3:42pm
L90DNY
I think that is the case, under further investigation today, I think with some fettling it will line up enough.
Post #553792 4th Aug 2016 11:06pm
