Home > Puma (Tdci) > Bolts
Page 2 of 2 <12
WarPig
Ive read that stainless steel bolts touching aluminium can cause a corrosive reaction. Need to use copper grease or similar where they make contact?
Or shall I get my coat? Very Happy
Post #49637 24th Dec 2010 11:36am
nakatanenga
Germany
We use aluminium based anti seize paste with our bolt kits. That sticks like shi... Copper grease gets washed awy pretty fast. WANTED:
SII or SIII in max 1.5k
Post #49640 24th Dec 2010 11:49am
dgardel
Italy
I have the Nakatanenga kit and it is the best on the market.
A good A270 class stainless kit is rated as 11.9 class steel bolts better than the cheeper original 8.8 class standard LR zinc plated. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #49641 24th Dec 2010 12:05pm
Lorryman100
I use Duralac Chromate paste when using dissimilar metals.
http://www.duncanyacht.co.uk/showpartnumbe...rID=248370
Post #49653 24th Dec 2010 1:51pm
DefenderOfTheEarth
Surely the bit I will be screwing these into is also steel? ( BEng Materials Engineering, Swansea 1997...) Defender 110XS SW gone... now VW California 180 4 Motion.
Post #49690 24th Dec 2010 10:05pm
Lorryman100
It sticks to the threads really well, on my boat when I need to replace fittings the threads coated in duralac are like new where as the bolt head or nut would be corroded. I don't claim to be a metallurgist just personal experience of using anti corrosive jointing compound when using different metals. As to needing it when using stainless steel bolts into a mild steel (zinc plated?) nut, I don't know the answer to that but would still use it. Also I cant tell just by looking what parts of the body work are steel or aluminium, so I use duralac just in case it's dissimilar metals.Thumbs Up
Post #49691 24th Dec 2010 10:27pm
DefenderOfTheEarth
Mild and stainless steel are slightly different un terms of reactivity but its a small "gradient."
All metals have a different measure if reactivity. The further apart they are on the reactivity table, the greater the corrosion potential. Zinc is very reactive so used as a sacrificial metal to protect less reactive steel.
That might make sense. Or it might not! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #49695 24th Dec 2010 10:49pm
Page 2 of 2 <12
