Home > Maintenance & Modifications > Alpine Roof Windows
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Alpine Roof Windows
Hoping someone could do me a massive favour and measure the distance from the back of the roof to the start of the window on a 90 hardtop.
I have spent a couple hours searching online and various forums, plenty of talk about doing it but no one has noted down that distance/measurement.
I know people will say it's another place to leak etc but I personally think it looks better and helps to let bit more light into the back.
Thanks in advance, if anyone gets a spare 5 minutes and has tape measure to hand. Otherwise, I am going to be driving around looking for a 90 to cheekily measure Laughing
Post #553273 2nd Aug 2016 11:48pm
CarMan
I agree with you and was keen to get mine done along with the rear quarters but on approaching Urban got this reply, so have canned the idea:
"I'm afraid it's not something that we would undertake here. We could supply a station wagon roof for you however we wouldn't want to be liable for any leaks if we were to cut the windows in etc as the top cut-outs in the roof have a small ridge from factory which helps the rubber seal to keep out any water"
Sorry, no help to you, but thought it might be worth passing on to you . . . . . . . Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #553300 3rd Aug 2016 7:15am
L90DNY
Interesting. Wondering whether some sikaflex along with the seals would do the job.
I already have the windows and seals and the place it is being resprayed at said no problem to cut the roof for them.
As it has van sides, I think the hard top roof makes it look a bit too van like for my liking, which is why I wanted to put the roof windows in. It has the rear quarter windows in already.
Post #553344 3rd Aug 2016 10:06am
Harry.O
I'm interested in how you get on with this, thinking of doing the same to the 110 to let more light into the back.
Sikaflex should do the job but may be quite messy also. Have a look for Captain Tolley's Creeping Crack Cure, it did a great job of sealing my roof join and windscreen seal.
Post #553363 3rd Aug 2016 12:24pm
X4SKP
Hello L90DNY
255mm (sorry 10" in Land Rover World) from the rear of a 90 to the start of the Rubber Seal...
Good Luck... SKIP
Post #553374 3rd Aug 2016 1:00pm
L90DNY
Thanks so much X4SKP !
I will update this thread, when it is done early next week
Post #553404 3rd Aug 2016 2:21pm
Happyoldgit
Be warned, they are a right royal b*****d to fit even with the apertures factory pre cut. With a plain roof your cutting really needs to be spot on otherwise you will end up regretting ever attempting the job.
Take the advice of someone who's done a few of these over the years - it's far simpler to buy a complete roof with the windows already fitted. Steve.
http://forums.lr4x4.com
Post #553422 3rd Aug 2016 3:50pm
X4SKP
That's OK L90DNY
Happyoldgit has a point, but it depends on exactly how you are having this done to your 90.
The OEM Safari Windows actually sit slightly recessed in a 'pocket profile' formed as a secondary
stamped process to a standard roof. The rubber seal sits a few mm into this 'recessed area'
(which you can just make out below). Retro fitted Safari Windows are common enough, but as suggested
who ever does this should follow the 'carpenters rule'... measure twice cut once... Shocked
Mine have been in and out to have the Vinyl Wrap taken right through and underneath the seals...
I saw the seals and windows refitted to another vehicle and it's a neat trick, inserting a length of strong cord
(or even electrical cable) right around the outer cavity of the seal (which is installed around the glass, the whole lot is positioned in place and the lip of the seal in one area sent through the aperture...the seal is then 'rolled' through the hole and into position by pulling the cord around the outside of the glass / seal... Thumbs Up
Good Luck SKIP
Post #553458 3rd Aug 2016 6:04pm
Happyoldgit
That's the standard way of doing it - the smaller the glass the harder the job. Steve.
Post #553504 3rd Aug 2016 8:52pm
L90DNY
hmmm, maybe it's not worth it. Depends if I'm going to get a roof rack.
Do think it looks a lot better though!
Post #553646 4th Aug 2016 11:42am
