Home > Puma (Tdci) > life span of shocks
Mother superior
life span of shocks
Gents
Ethel the 110 has just clocked up 60K, and she's getting a bit crashy, bless her. am I right in thinking that it's new shockers time?
PS if so I'm going with Terrafirma, 'cause they're silver and black so will match the car !
Thanks
Wes Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #552096 29th Jul 2016 10:07am
Changed mine at around 45k, bushes often before that.
That's ti get the best from them. Usability wise they would go on longer.
Post #552178 29th Jul 2016 4:15pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I used terrafirma on my previous 110. Whilst they transformed the ride the outers were covered in surface rust after 6 months. For that reason I would not buy again.
Post #552186 29th Jul 2016 4:58pm
Changed my rears at 150k miles, fronts are still fine at 200k miles.
I'm on about the 8th set of rear lower bushes, though!
Post #552205 29th Jul 2016 6:00pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
I put terrafirma shocks on mine, they were ok, but nothing special.
Swapped over to konis, what a difference.
Post #552227 29th Jul 2016 8:02pm
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
How did you set up your Koni's?
Post #552274 29th Jul 2016 10:32pm
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
...er......Put Britpart on mine,rides lovely.
Post #552285 29th Jul 2016 11:07pm
pannawonica
Australia
At @80kkms my 2.4 110 was like a boat, the heat, loads pulled and carried and off road they where shot!😂 However koni heavy shocks, set up 35% front, 60% rear made it better than new. Bushes were almost like new. Handles better than new with 130 springs on the front. Big question too me is how long they last over oem! Bang for your buck so too speak! Very Happy Thumbs Up
Post #552293 30th Jul 2016 3:29am
williamthedog
On the second damping setting, oh and theres britpart h/d standard height springs as well Thumbs Up
Post #552295 30th Jul 2016 6:09am
Rear top mount bushes okay? I bizarrely had the R-O-S top mount bush go
Post #552348 30th Jul 2016 11:09am
Don't seem to have trouble with the upper bushes, I think I changed them once. It's the lower bushes that are spectacularly useless!
Post #552472 30th Jul 2016 10:00pm
nickhodgson
If you did 60k on your genuine shocks why don't you replace them with the same.
Actually I would think the shocks are still good and just some new bushes will help. At 60k also check your rear axle ball joint and A frame bushes. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #554675 9th Aug 2016 10:04am
hornet
Re: life span of shocks
Mother superior wrote:
Gents
Thanks
Wes
Had to change my rear at 150.000 km and changed front at same time even they still worked well. Used Koni Heavy Track models which made no difference to genuine shocks in my opinion. In total € 400,--
When only the bushes fail you notice a "rumble".
Post #554731 9th Aug 2016 2:55pm
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Shocks for RHD Van 110
Since we have a shock thread here, what make/model of shock, with which spring (genauine) will give a good ride to a medium-loaded 110 Van Cab 300TDi? 2013 110 - Keswick Green
1995 ExRAF 110 Utility
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #554753 9th Aug 2016 4:41pm
