Home > Maintenance & Modifications > Brake caliper, union and bleed and eh?
agentmulder
Kuwait
Gidday folk,
I'm refurbishing some rear 110 puma era calipers, what's the circled bolt up there?
It's a weird size, something between 9 and 10mm... Almost rounded it off Shocked
>>edit, it's not the bleed or the union...
 Solved the bowel problem, working on the consonants...
Post #551010 25th Jul 2016 2:35am
dorsetsmith
http://www.rimmerbros.co.uk/Item--i-SMG000010
i use 11m ring spanner but i use 6 point type and flare nut spanner pipe union
Post #551023 25th Jul 2016 7:26am
agentmulder
Kuwait
I should elaborate on the title:
It's not the bleed, but situated kind of between the bleed and the union.
The bleed has a nice 11mm hex (or 13mm cant recall, but my 11/13mm flare nut does it).
This one is between 9 and 10mm and appears to just be a threaded nut... Solved the bowel problem, working on the consonants...
Post #551026 25th Jul 2016 7:29am
agentmulder
Kuwait
I cant see it on the TDCI parts thingo:
(14 - 'SMG000010' is the bleed though) Solved the bowel problem, working on the consonants...
Post #551027 25th Jul 2016 7:38am
dorsetsmith
yes see my link ^^^^ with pic
Post #551028 25th Jul 2016 7:41am
agentmulder
Kuwait
Yes?
3/8" ?? Solved the bowel problem, working on the consonants...
Post #551029 25th Jul 2016 7:48am
agentmulder
Kuwait
I've seen your link, the pic on that page is a bleed nipple:
Yes this nipple is on my caliper - it has a nice 11mm nut and a outlet for the fluid.
But the bolt I refer to does not have an outlet or an inlet, nor does it have a nice 11mm head. it's more like a 3/8" but that's just a guess.
I don't know what it is.
Sorry, my pic isn't very clear Neutral Solved the bowel problem, working on the consonants...
Post #551035 25th Jul 2016 7:52am
I believe that it plugs a hole used to produce the internal fluid galleries in the caliper, and is not generally available as a spare part since there is no need ever to remove it. If you have a damaged one, you will need to determine thread form and dimensions and see if there is anything suitable generally available, or else get one machined for you.
Post #551037 25th Jul 2016 8:03am
agentmulder
Kuwait
ahhh, ok... a manufacturing hangover
I guess if you're drilling with a machine centre with ATC or similar it might make sense to quickly tap it then and there (?? rather than plug it up with molten metal in some form or other later (heat = $$))
The non-metric nut size I guess is intended as a first defence in terms of people like me opening it up. But generally available, unlike a left handed and tapered thread with those heads you see on bolts in posh airport toilets Laughing Solved the bowel problem, working on the consonants...
Post #551041 25th Jul 2016 8:12am
It is, I think, likely to be a standard thread (just conceivably BSP though, depending on the age of the tooling). A more interesting question might be how it seals.
Do you actually need to remove it? Provided that it is in-situ and doesn't leak, ot probably doesn't matter if the head has been mullered.
Post #551051 25th Jul 2016 9:21am
agentmulder
Kuwait
I don't need to remove it, especially now I know what it does - er... did Rolling Eyes Laughing
I suppose a conceivable reason would be to assist clearing out gunk etc. if you've had a fun evening pushing out seized pistons with a grease gun. But yeah, it's fine as it is, I wont touch it anymore, my one attempt was just exploratory and I foresaw tears before bedtime so stopped before any movement - or damage - which I predict would have happened first. Solved the bowel problem, working on the consonants...
Post #551057 25th Jul 2016 9:33am
Use an airline - carefully - to clear the passages.
For future projects a useful tip is to eject the pistons as far as practicable before removing the caliper from the vehicle. Also, if you intent the seperate the two halves of the caliper (a controversial subject, I know) then it is often easier to crack the bolts (and torque them up fully afterwards) when the caliper is bolted to the vehicle - it is the easiest way to hold the caliper securely.
Post #551062 25th Jul 2016 9:43am
agentmulder
Kuwait
Did it that way Thumbs Up Solved the bowel problem, working on the consonants...
Post #551064 25th Jul 2016 9:48am
