Home > Td5 > Which 10AS for a 2004 Td5?
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
Hi all,
I have a 2004 110 Td5 with starting issues. The culprit is narrowed down to the 10AS unit.
As my 110 Td5 has central locking, I've been advised that I that I need the 'posh' 10AS with the central locking relays built-in.
I've been looking online for a replacement, and the part number and prices are all over the place! There seems to be quite a few different part numbers for the 10AS. Does anyone know if AMR6429 / YWC106280 / YWC500640 is the correct part, i.e. 10AS with central locking?
Also can they be used interchangeably with the Td5 engine ECU? The AMR6429 is approx. £160; the YWC500640 is close to £500! Shocked
Post #550533 22nd Jul 2016 10:57pm
dorsetsmith
you can get it repaired
http://www.technozen-electronics.co.uk/lan...-services/
if you remove the dash you will find the 10AS read part number from it
Post #550559 23rd Jul 2016 7:22am
kyvlle
Cheers! I'll keep that service in mind. My 110 is currently with a local independent. I'm now trying to source a working 10AS so I can get it running again.
I have the YWC106280 unit, and have just been told that the AMR6429 will fit too (if I can find a New Old Stock).
Post #550600 23rd Jul 2016 11:19am
dorsetsmith
Post #550625 23rd Jul 2016 1:40pm
