![]() | Home > Tdi > Front bumper removal |
yes 4 bolts not threaded into the chassis in to this
![]() Click image to enlarge Last edited by dorsetsmith on 20th Jul 2016 2:18pm. Edited 1 time in total |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
Yes just the four bolts, but the nuts are not captive or welded into the chassis but rather slide into little groves within the chassis and are held in place with spring clip fasteners . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 ![]() ![]() |
As above probably the most worried free part to remove
Cheshire Dave Member Since: 05 Jun 2014 Location: Chester Posts: 119 ![]() ![]() |
So do these pieces slide in from the front on the chassis ? I suppose I'll know when I undo them !!
Dave |
![]() Click image to enlarge slide on to the bumper red arrows ![]() Click image to enlarge |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
Thanks guys I'm with it now.
Even I should be able to manage that ! Dave |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1181 ![]() ![]() ![]() |
Did you manage?
I removed my winch bumper to fit recovery points and was only able to get half of them back into place ![]() Still haven't had a chance to have another attempt at it ![]() |
cypermethrin Member Since: 15 Dec 2010 Location: Berkshire Posts: 99 ![]() ![]() ![]() |
You say that is the easiest part to remove but it still took 40 mins to get the old bolts out...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18026 ![]() ![]() ![]() |
When I bought my Defender the 4 bolts were simply dropped into their holes and not screwed into anything!
They've now got nylocs on them, it is possible though fiddly to use normal nuts instead of the nut plates. |
No bolt on a Defender is ever easy!! Try removing the rear seats from a pre Puma SW....if you're lucky, they'll snap on the first turn.
never mind that try the one in the seat box 4 hr to get two m6 bolts out from B pile
![]() cutting disc in end ![]() |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Getting the bolts back into the plates can be the hardest part. Fiddly lining up the holes.
I probably matched that with them, I even went machine mart to buy an air chisel!!! Which didn't work either! |
