Home > Puma (Tdci) > "Oil Can Sign"....Dash Waning Light?
Pickles
Just noticed this warning light in the dash, which goes out a second or so after start up,...is this normal
Oil Pump recall has been done, can't remember seeing this light before, but maybe it's always been there.
What about you guys,....do you see this light, which goes out a second or so after start up?
Pickles.
Post #549920 20th Jul 2016 8:54am
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
It's not an oil pressure check light is it that lights on start then goes out normally. Think my does it but away from wagon at the moment
Post #549923 20th Jul 2016 9:24am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
if its red then yes, its your Oil pressure Light, will be on while the ignition is on, then when the pressure is seen at the sensor the light will go out, if it stays on for more than a few seconds, or if it comes on while driving then switch the engine off straight away to investigate.. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #549930 20th Jul 2016 10:07am
Cupboard
Mine goes out when the alternator light goes out, or if I don't wait for the glow plugs then it goes out when the engine management and glow plug lights go out.
It's so consistent I assume that's just how the logic works.
Post #549955 20th Jul 2016 12:23pm
