Home > Maintenance & Modifications > PAS bleed - how to get to nipple!!??
Active Planner
Italy 2011 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Can anyone please help me. I am having some issues with the steering on my 110 puma - grunt turning left, and intermittent slack in straight ahead position. Don't know if both are related, but would like to bleed the PAS to make sure all is ok with the fluid (level is within marks on dip stick - although I have two lines on it - assume needs to be to top line?)
Looked at it today and can't figure out how to access the bleed nipple. The only way I managed to reach it was to part remove lower fan cowl and part remove air filter box - neither removed fully as looks like I need to either drain the cooling system or air con!!?? Now to bleed/replace the PAS fluid, the manual says to run the pump - I don't fancy ding that with parts only partly removed! Surely it is npot necessary to drain down systems just to access the nipple?
Has anyone flushed their PAS and if so, how?
The slack in the steering wheel is apparent sometimes, but not always, so don't really want to try tightening the steering box - any ideas anyone?
Post #548794 14th Jul 2016 6:56pm
Don't quote me I'm no expert but I thought all the bleeding that was required was engine running with front wheels able to swivel so you can turn the steering lock to lock a few times and that would purge the PAS fluid through the system.
Also keep checking the fluid level, top up likely to desired level.
Post #548800 14th Jul 2016 7:10pm
Active Planner
Hi Steve, I also have read this, but was wanting/thinking about replacing the fluid so I know I am starting from 'as new'.
Post #548803 14th Jul 2016 7:20pm
I'm pretty sure the same applies. Thumbs Up
Post #548807 14th Jul 2016 7:33pm
Active Planner
Am I missing something - how does the old fluid leave the system?
Post #548808 14th Jul 2016 7:36pm
Your right there is a drain, but I'm afraid I don't know the location of it.
Someone with WSM details would best guide you, I have one but not to hand.
Post #548860 14th Jul 2016 9:54pm
