![]() | Home > Puma (Tdci) > Oil Filter cup leaking following oil change |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4278 ![]() ![]() ![]() |
I had to swap the fillet only a couple of weeks ago. Not much oil company comes out, maybe 250ml, athlough it feels like a lot more when it is trickling down your sleeve!
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
What did you swap the fillet for? Sirloin or maybe a nice bit of cod?
![]() AlanH. |
It was Fillet 'O Fish, and I swapped it for McNuggets if you must know!
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Did you replace the O ring into the correct groove in the filter canister? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Oh yes, all done right - as I said, I suspect either the o-ring failed or the bowl has cracked. Will know why on Saturday once I get it off. Was just curious to how much new oil I'd lose so I can make sure I have enough to top up afterwards.
Cheers Mark |
get your self spare one i.e o ring and bowl
![]() LR004508 or fords part number 1303477 |
