Home > Maintenance & Modifications > Loctite 660 - gap filler solution for spline backlash?
agentmulder
Kuwait
So an idea just cropped up after my new halfshafts arrived...
I mated them up with the flanges (new also) to see how much backlash they'll have from new - quite a bit!
Which got me thinking, why not fill up the gap with something elastic to take up a bit of the shock?
Lo and behold: http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627715073
Questions:
1. Anyone used this?
2. Anyone used from new?
If so, which way would you bias the splines when applying it? Centre/average or already pushed in the forward drive position? Solved the bowel problem, working on the consonants...
Post #547738 11th Jul 2016 10:49am
It would be interseting to hear how you get on if you do try this (and there is really nothing to lose by trying).
I have in the past used a Loctite product on my drive flange splines, but I cannot now remember if it was 660 or something else. Whatever it was, I assembled the rear halfshafts and flanges with the Loctite, left it for a week in the kitchen to cure, then fitted them. It lasted perhaps two weeks before it gave up under the load and came out as powder! Big Cry
It is however quite likely that it wasn't 660, and it would be interesting to know how well this fares.
Post #547778 11th Jul 2016 1:12pm
agentmulder
Kuwait
Will do Thumbs Up
It's not cheap though, will get 50ml and see how far it goes.
It's pretty much a crappy weld. Although it's no where as critical as in weld I'm now thinking about how I'm going to line them up nicely ... Mr. Green Solved the bowel problem, working on the consonants...
Post #547919 11th Jul 2016 9:38pm
e.khromtsov
Russia 2007 Defender 110 Puma 2.4 SW Stornoway Grey
I experimented with Loctite on the rear driving members' splines: Loctite 648 on the left side and Loctite 660 + Loctite 7649 activator on the right side. The cure time was about 6 hrs (there was a need to drive then). The result was negative - backlash returned after two days of driving on Russian "roads". The inspection showed little compound debris on driving member and half-axle, I cleaned them with a wire brush, greased and reassembled.
I plan to retry this experiment with 24 hrs cure time and larger amount of Loctite 2 weeks later.
Post #549275 17th Jul 2016 10:43am
agentmulder
Kuwait
How did you centre the spline in the flange?
I think that, just like in a weld, having them centred (same axis) is critical. Solved the bowel problem, working on the consonants...
Post #549444 18th Jul 2016 4:34am
e.khromtsov
I just moved flange close to circlip. My driving members are new and halfshafts are not badly worn, so there's almost no radial play in this splined joint, only slight tangential one.
The first time, I didn't remove halfshafts, just applied Loctite on prepared splines, installed driving member and wheel on the vehicle and left Landy alone (~15hrs one side, ~4hrs another). The second time I removed both halfshafts, cleaned, degreased, applied Loctite on halfshaft, placed driving member on halfshaft, quickly installed circlip and positioned driving member as close to the circlip as possible, then fixed halfshafts vertically and left them for ~6 hours.
I think, the problem is lack of Loctite 660 between the splines - large amount was pressed out, when I fitted driving member. The next time I will use more Loctite, distribute it better and apply heat to the joint (it will increase the rate of cure, according to http://www.loctite.sg/sea/content_data/937...mpound.pdf ).
Post #549481 18th Jul 2016 9:28am
