Home > Maintenance & Modifications > Removing the heater drain bung.
Cupboard
Any reason why I shouldn't remove it? I'm talking about the rubber thing marked here in a picture from dorsetsmith
The reason I ask is that when I've cleaned it out it seems to last less than a month before getting bunged up again.
Removing it won't alter the amount of stuff flowing in to the engine bay, but will stop it backing up in the air inlet box. I think.
Edit: I should add that it's actually been out already for a few weeks because I forgot to put it back in again.
Post #545955 4th Jul 2016 4:27pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I've had mine out for the past 2 years, haven't noticed downsides Thumbs Up
Post #545971 4th Jul 2016 5:21pm
ericvv
With a snow cover installed, nothing will enter that can block that rubber drain.
But I would like to check a similar rubber drain that seems to be installed above the gearbox somewhere as drain for the airco condensation, and I just cannot locate it when lying under the truck and try to find it... Rolling Eyes
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #546001 4th Jul 2016 7:27pm
Mo Murphy
No reason at all.
50 Shades of Pennine Grey
Post #546013 4th Jul 2016 8:12pm
Cupboard
So what's the point of it then?
If I'm driving along a really dusty track will it suck any more dust in? Might actually make it less dusty I guess!
Post #546102 4th Jul 2016 10:59pm
driver9
I take mine out in the winter to help drain any water away and also helps to make the heater more efficient by allowing warm air to be sucked in from the engine bay. In the summer (if we have one) I put it back in place to reduce the air flow from the engine bay and make the air con more efficient. Probably a placebo effect but it works for me.
Post #546136 5th Jul 2016 7:44am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I think it's purpose is to stop water being sucked in when wading in deep water, while letting after out that gets in from above. However, I think by the time the water is that high it will have come into the cab via the door seals etc... Smile
Simon
Post #546142 5th Jul 2016 8:03am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I run without one. Mine has never had one. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #546310 5th Jul 2016 8:04pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
An old thread, but thank you. Windows were misting up at the weekend. I've just removed that bit of rubber and a lot of water came out. I'll leave it out now.
Post #802740 18th Nov 2019 9:36pm
