![]() | Home > Technical > Emergency brake assist |
AdrianCR Member Since: 23 Aug 2009 Location: Costa Rica Posts: 53 ![]() ![]() |
Hi. is emergency brake assist a new feature on 2015-2016MY defenders, owners manual explain is part of DSC. If so, it is just a software update?
thanks. |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Probably software yes:
http://auto.howstuffworks.com/car-driving-...ssist4.htm as DSC appeared only in the last few months before Defender production ended. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
My 2015 110 had EBA, basically if you brake hard and suddenly then it takes over braking and stops the vehicle as quickly as it can using all of its sensors to find maximum traction. Almost like launch control in reverse
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I found it particularly annoying. Super sensitive, even gentle corners on a rough surface would trigger it. When I had my 2015 model I wanted it removed lol 2002 90 Td5 Station Wagon
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
You'll find that something called "good driving" has much the same effect, and is a lot cheaper! ![]() |
