Home > Maintenance & Modifications > Removing Puma Centre Console
Page 2 of 2 <12
languedoc
Scotland 2008 Defender 110 Puma 2.4 CSW Alaska White
Pass.
I cant see on my one, its in pieces in the body shop just now!
Post #544566 29th Jun 2016 4:35pm
If you want to bypass the heater completely you'll either have to connect a new pipe from the valve outlet (the outlet leading to the matrix) to wherever it is that the outlet from the matrix connects back to the engine, or, which is probably simpler, just clamp off the pipe from the valve to the matrix leaving it all connected. A brake hose clamp would be ideal.
Post #544599 29th Jun 2016 6:13pm
Grenadier
Blackwolf, I'm not sure I should say this on what I assume is probably a firmly heterosexual website (not that I have any issues with homosexuals, but given my best mate is and would steer clear of Defenders, I would suggest they will be in the minority in this website.....but welcome to you all if you're here), but I could kiss you Shocked
After the failed test, dove under the bonnet again and gave the valve a really good seeing too. There was a notable, large 'click' which seemed to free movement up a bit. Closed the lid, went to bed. Yesterday, (hot day - 30c), drove for a good couple of hours and nothing. Nada, rien, zilch. No heat, no hot plate, no hot air from the dash vents. Mrs a Grenadier wondered why throughout the drive I had my hand stuck down between the dash and gear selectors. Normally it's there within 10mins, but not this time. It's cold (as cold as it can be in a Def). Fan works blowing that cold-ish air as well. Didn't want to tempt fate by twisting it to hot, so will leave it for summer as the 'hot' setting if the valve gets stuck again is so good it'll be great when we hit winter Rolling with laughter
Anyway, as ever your knowledge was bang on the money and fantastically useful. Thank you oh sage of the Defender world Bow down
(You don't have to have the kiss if you don't want to.... Whistle ) Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #545238 2nd Jul 2016 6:34am
I'd rather settle for a virtual beer if that's ok with you! Embarassed
Glad to have been of help.
Post #545248 2nd Jul 2016 7:36am
Page 2 of 2 <12
