![]() | Home > Td5 > G Force Oil |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 ![]() ![]() |
Any good?
http://www.ebay.co.uk/itm/172122201158 1999 Td5 110 CSW 1961 Series 2 88 LPG |
I'm using it in my 200Tdi and she hasn't complained.
6k oil services so its only in there a 3 months so probably not long enough to be an issue but I'm happy with it ![]() Self confessed mileage hunter ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1661 ![]() ![]() |
nope it should be 5-30 fully synthetic to the correct spec.
go direct
www.opieoils.co.uk |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
recently had some issues with an oil brand at work that I wont name on here but has a high evaporation rate and results in too much oil mist entering the closed circuit breather system, carbonising the turbo and intercooler etc. I would always suggest using a premium brand of the correct grade and spec DEFENDER 90 TDCI XS,
Thanks for the advice. I'm used to much cruder LR engines which will take any old lube. 1999 Td5 110 CSW
yes older engines are generally less fussy but the emissions kit creates all sorts of extra considerations DEFENDER 90 TDCI XS,
