![]() | Home > In Car Electronics > Wiring question |
wrong information posted see below 07 -12 radio wiring read your post on my phone and miss your reg date no wonder you confused
![]() Last edited by dorsetsmith on 29th Jun 2016 5:00pm. Edited 3 times in total |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 ![]() ![]() ![]() |
Ah okay thanks, so there should be the wires for the lh speaker stashed somewhere with one black/yellow one black/orange. Thanks!
Lew |
Hi there again,
Quick question if I can, I had a root around in the dash to locate my speaker wires and am now left a little confused, the only loose wire I can find has two wires running to it coloured black/white and black/brown. These match up with the other two wires in the back of the iso block. However unlike the drivers side which is split into two separate connectors this is a single black connector. Also you can see from the pics that the drivers side contains two connectors and 4 wires whilst the passenger is just one connector of two wires? Iso block with 4 wires [URL=] ![]() Click image to enlarge[/URL] Drivers side connections [URL=] ![]() Click image to enlarge[/URL] Passenger side? [URL=] ![]() Click image to enlarge[/URL] Anyone any ideas on this? Cheers, Lew Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
See this thread, identical question:
http://www.defender2.net/forum/topic40776....eaker+loom The three pin plug is not it ![]() ![]() ![]() |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Looks to me like it's wired for a very basic Mono radio (is there such a thing ??)
The ISO block is only wired for one speaker and a supply, the connectors on the second picture are certainly the same type as for a speaker, odd that they have two wires in each one though, that's suggesting there's provision for a second speaker somewhere. The connector shown on the last picture is not for a speaker or anything else to do with a radio, I don't know what else though. |
Haha thanks, I just found them, I can testify that they are indeed taped in the most awkward spot land rover could find I'm sure. One very sore hand later I managed to free them up, interesting that the black connector seems to be provision for a tweeter, makes life a bit easier when I come to put them in!
Thanks for your help, Lew |
Yes the 3 pin connector is for the dash-top tweeters. There will be one the other side too.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
2007 > 2012.
try this will be more helpful
Thanks that makes a lot more sense!
https://1drv.ms/b/s!AtZSoWFHDgnGhDbxYedTopmyd1rA manage to transfer it to one drive
Thanks very much
