![]() | Home > eBay & Bargain Spots > Waeco Mobicool W40 fridge - £60-00 - TESCO |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Does it say on the specs the current/Watts draw when on 12v? 1999 Defender TD5 110
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
4 Amp Peltier unit
@ 12v that's 48w? 1999 Defender TD5 110
Correct
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Used it yesterday and here are my thoughts.
Very light and the has wheels and a pulling handle so easy to move around You can regulate the temperature with AC only. Under DC power the fan whirs away at max speed which isn't a problem when driving due to standard landy noise cancelling capabilities but was annoying that you could not regulate. I have a dual battery solution so was not worried about flattening the battery when left in landy for hours on end Kept things very cold As it has has wheels i decided to mount on a towel to prevent it easily moving around, and will create a better solution in the coming weeks. Overall rating: For £60 I think it is a bargain and does what it said on the tin, if it gets hot then all bets are off as it only goes 18 degrees below ambient but hey this is the loverly UK and how often do we get temperatures in the 20's ![]() Cheers Steve |
