Home > Td5 > ECU memory TD5. Fact or fiction?
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I was told when a car's ECU is disconnected from the battery and then reconnected (after a repair for instance) it could take a few hundred miles for the ECU to re-learn.
Is this bobbins or fact and if fact does the same apply to my TD5 2001? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #543094 24th Jun 2016 7:04pm
davew
I don't think that's the case with a TD5 ECU, some of the engine ECUs (like the later V8 petrol ones) have adaptive values that allows the ECU to learn your normal driving styles and adjust itself to give the best fuelling and ignition. They can take a few hundred miles to adapt but as far as I remember they don't reset after a battery disconnection, only after you use Textbook to tell it to reset. http://www.yorkshireoffroadclub.net/
Post #543098 24th Jun 2016 7:19pm
MC84
Thanks for the info, much appreciated. Mike
Ford 100e 1959
Post #543100 24th Jun 2016 7:29pm
Not sure about the Td5 but the Puma ECU certainly learns as it lives. It doesn't however forget what it's learned if powered down.
For example, on a new ECU it will learn the fuel pump calibration autonomously and fairly quickly. If you were to change the VCV and not carry out a forced relearn with a diagnostic/programming, it will eventually recalibrate itself anyway. It will do this much, much quicker on a low mileage vehicle than a high mileage one.
You can establish this behaviour if you change the VCV and don't (or can't) recalibrate. If you keep clearing the resultant "pump relearn not performed" DTC it will eventually stop coming back, but this will happen quicker the lower the mileage of the vehicle.
It's all a bit mysterious and only the people who coded it probably really know how it works.
Post #543114 24th Jun 2016 8:13pm
MC84
Thanks Gents Mike
Ford 100e 1959
Post #543460 26th Jun 2016 8:56am
