![]() | Home > Maintenance & Modifications > Adjusting the handbrake cable |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
I've just replaced the handbrake cable and after a week or so, it needs a bit more tension
(its now not tight enough to pull the handbrake down when its off and the handbrake warning light stays on ) Is there an easier way to adjust it rather than unbolting the handbrake lever ? There doesn't seem to be an easily removable panel above it ( next to the drivers seat ) Its a TD5 110 CSW Cheers |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Access from underneath or via the panel in the centre of the seatbox.
