Home > Td5 > Dash removal
TOP5N
Dash removal
Hi all... My bulkhead is showing some rust behind the dash just under the windscreen... I want to get it it properly to treat it and repair it, but it looks like the dask could do with coming out... Is this a nast job, or something i can do with a few normal tools...
Chris
Post #542435 22nd Jun 2016 3:48pm
mk1collector
A couple of different size screwdrivers and a 10 mm socket or spanner is about all you need but there's lots of fixings so I hope you have a good memory for when it goes back Mr. Green Ray
My build thread
Post #542442 22nd Jun 2016 4:00pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I've just stripped mine for the same reason. It's all back together now but like mk1collector said you need a good memory. I took a few snaps to help as almost every screw seemed a different length! I tried to replace as many of the bolts/screws with stainless ones.
Post #542455 22nd Jun 2016 4:45pm
gilarion
Memory can fail, so take lots of pictures. Fairly easy job, though putting the heating duct tubes and cables back can be a bit of a bug*er. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #542475 22nd Jun 2016 6:05pm
ericvv
Re: Dash removal
Chris
Normal tools is all it takes Thumbs Up But indeed, think twice how it all fitted together before you take the dash out. Laughing
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #542507 22nd Jun 2016 7:34pm
