Home > Tdi > water in cab
yanto
Wales
water in cab
Hi guys
Had some really heavy rain the last few days. The area where the jack is kept in my 90 pick up was full of water. Is it coming from the bed? The landy was parked on a bit of a slope facing down.
Any help would be great.
Post #541495 19th Jun 2016 2:14pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Main culprits would be seals between cab and bed or the window seals. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #541497 19th Jun 2016 2:19pm
yanto
Wales
Sorry guys, this was meant to be on Td5 section.
Post #541498 19th Jun 2016 2:20pm
Mo Murphy
Park it facing up ?
Mo 😉 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #541536 19th Jun 2016 4:09pm
yanto
Wales
Haha get water in through the head lining then Laughing
Post #541567 19th Jun 2016 6:30pm
miker
They leak in the same places, doesn't matter which engine!
Post #541586 19th Jun 2016 7:29pm
dorsetsmith
seal leak top cab rear window had same problem
problem fix now and no need for drain hole Whistle
Post #541587 19th Jun 2016 7:31pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
The drain holes by the seatbelt reels must be blocked or they maybe forgot to fit them at the factory, better get the drill out and retro-fit them Laughing
Post #541725 20th Jun 2016 9:49am
steve E
Wales
I had a leak in same area coming in from the rear window,due to the channel strip perishing
I used some new double glazing window strip from my neighbour which sorted it out, although it did stop you opening the slide window. I never used it anyway and you couldn't see any difference.
Post #541734 20th Jun 2016 10:15am
dorsetsmith
channel strip perishing, that the problem i had with my one but the leak was the window to cab seal at the top
Post #541740 20th Jun 2016 11:01am
Browny90
United Kingdom 2004 Defender 90 200 Tdi SW Stornoway Grey
drill some holes Thumbs Up My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey Smile 2 years off the road, but getting close to completion now
Post #541745 20th Jun 2016 11:24am
yanto
Wales
Thanks guys, it's got 4 holes with plastic grommets in. Can someone post a link for the seal for the window please.
Post #541896 20th Jun 2016 9:06pm
steve E
Wales
I was told I would have to buy the whole unit when I enquired with Craddocks. Shocked
so I patched it with double glazing strip into the window channel.
Post #541985 21st Jun 2016 9:00am
