![]() | Home > Maintenance & Modifications > EARLY LANDROVER 110 sailsbury axle shock mount HELP |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
Yes. This is the simple solution. It is possible to buy the lower shock mounts to weld on. Drain oil and pull shafts first obviously and simpley weld on new one and remove all traces of old one.
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
I would say drilling holes and welding in sleeves to new chassis is easier than doing a good strong weld on the old axle. When welding the old axle you also have to get the angle of the bracket correct which is not so easy when I have done it. On your old chassis you have information to make a template. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
You have the bracket the other side of the axle to use for positional information on the tube. Drilling/welding a galvanised chassis would be less than ideal - think I'd go with the axle bracket. Though you need a fairly chunky welder as the metal is thick.
Must be a very early 110 as you say - any pics? ![]() |
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Yep she's not pretty or original but i love her ![]() ![]() Click image to enlarge Another slight problem if discovered is my rad mount is taller than what's in now Do i just need a defender 200tdi frame ? ![]() Click image to enlarge ![]() Click image to enlarge Last edited by Wandathe110 on 6th Jun 2016 9:21pm. Edited 1 time in total |
Well that never worked how i thought it would
Looks great.
You've probably got a Discovery radiator frame, popular conversion when fitting a Disco 200Tdi using the donor vehicle frame. However as it is an inch and a half or so taller one has to cut the brackets down. You'll need to either cut yours down or fit a Defender 200Tdi radiator, intercooler, and frame assembly. |
Thanks I'm going to go the axle bracket method, just need to find one to suit the sailsbury, the rad i will have a play about with but I don't fancy cutting a new chassis
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Don't forget to get some proper number plates too !!
![]() Not at top of things to do in order, but should be on the list ![]() |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 ![]() |
I welded new mounts on my Salisbury axle - All the aftermarket replacement mounts available are not the same as the originals with the pressed lip on them - instead them are just folded metal without the lip as reinforcement.
I ended up plasma cutting two used shock mounts off another Salisbury with a knackered diff and welding them on mine. |
