Home > In Car Electronics > Advice required on wash wipe switch
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Can this be fixed?
My delightful son has been "playing" in my car just now. We are meant to be going camping tomorrow!!
It is the wash switch wire that has pulled out I think. When I put it back together and push the stalk in the washer is on permanently (presume it is switching to earth through the body of the stalk unit).
Any emergency advice this afternoon would be much appreciated
James 2002 110 td5
Post #535655 29th May 2016 4:26pm
Jimb1978
Now I've calmed down and the red mist has cleared, it was an easy fix. I realised the bare wire is just an earth for the stalk and it was the actual button on the end that had stuck down is I was trying to push it into the splined hole.
Thanks anyway. It's nice to be able to call on the forum in times of need
James 2002 110 td5
Post #535663 29th May 2016 4:47pm
Anderzander
I had the same thing with my daughter (4) - it was a relief when I realised it just pushes back in Smile
Post #535665 29th May 2016 4:57pm
agentmulder
Kuwait
You're lucky the plastic receptacle didn't crack.
That's not so fun... Solved the bowel problem, working on the consonants...
Post #535731 29th May 2016 9:28pm
Jimb1978
I know. That would have been game over I fear. 2002 110 td5
Post #535735 29th May 2016 9:37pm
Alien
Australia
I had the little earth wire break on mine so I had no washers.
I had to pull the lever out to refit the wire.
There is not a lot of length on the switch wire, I see your looks intact.
Good to hear it's fixed, enjoy the trip. Cheers,
Kyle.
Post #535750 29th May 2016 10:40pm
